Salta al contenuto principale
Nikon D40 Viewfinder Replacement
Cosa ti serve
    1. Nikon D40 Viewfinder Replacement, Back Cover: passo 1, immagine 1 di 1
      • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
      Chiedi a FixBot
      Aggiungi Commento
    2. Nikon D40 Viewfinder Replacement: passo 2, immagine 1 di 2 Nikon D40 Viewfinder Replacement: passo 2, immagine 2 di 2
      • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
      Chiedi a FixBot
      Aggiungi Commento
    3. Nikon D40 Viewfinder Replacement: passo 3, immagine 1 di 1
      • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
      Chiedi a FixBot
      Aggiungi Commento
    4. Nikon D40 Viewfinder Replacement: passo 4, immagine 1 di 1
      • While pulling the bottom down, remove the back of the camera.
      • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
      • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
      Chiedi a FixBot
      Aggiungi Commento
    1. Nikon D40 Viewfinder Replacement, Viewfinder: passo 5, immagine 1 di 1
      • You will be able to see the ribbon cables coming out from the back panel, disconnect the cables.
      • Be careful not to pull too hard on the ribbon cables.
      Chiedi a FixBot
      Aggiungi Commento
    2. Nikon D40 Viewfinder Replacement: passo 6, immagine 1 di 1
      • Slowly push the upper body up until you see the frame of the viewfinder
      • Be careful while pulling the top camera body.
      Chiedi a FixBot
      Aggiungi Commento
    3. Nikon D40 Viewfinder Replacement: passo 7, immagine 1 di 1
      • Use a spudger to keep the upper body separate from the printed circuit board.
      • Wiggle the plastic eyepiece out of the frame. This may require some force.
      Chiedi a FixBot
      Aggiungi Commento
    4. Nikon D40 Viewfinder Replacement: passo 8, immagine 1 di 1
      • Remove the viewfinder with the plastic opening tool.
      • Do not push too hard while using the opening tool.
      Chiedi a FixBot
      Aggiungi Commento
    5. Nikon D40 Viewfinder Replacement: passo 9, immagine 1 di 1
      • The viewfinder has been removed!
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Amy Chen
Membro da: 01/23/14
193 Reputazione
Una guida realizzata
Cal Poly, Team 6-19, Maness Winter 2014 Membro di Cal Poly, Team 6-19, Maness Winter 2014
CPSU-MANESS-W14S6G19
4 Membri
7 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 40
Tutti i Tempi: 4,035
