Salta al contenuto principale
Nikon D3200 Memory Card Replacement
    1. Nikon D3200 Memory Card Replacement, Memory Card: passo 1, immagine 1 di 1
      • Locate the memory card compartment on the right side of the LCD screen.
      Chiedi a FixBot
      Aggiungi Commento
    2. Nikon D3200 Memory Card Replacement: passo 2, immagine 1 di 3 Nikon D3200 Memory Card Replacement: passo 2, immagine 2 di 3 Nikon D3200 Memory Card Replacement: passo 2, immagine 3 di 3
      • Gently press and slide the grooved compartment door to the left.
      • Let go of the compartment door and it will swing open.
      • Insert the memory card imitating the diagram pictured outside the compartment door.
      • Make sure to push down once the memory card is inserted to lock it in place.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 12 persone hanno completato questa guida.
CSU Fullerton, Team 1-3, Bruce Fall 2014 Membro di CSU Fullerton, Team 1-3, Bruce Fall 2014
CSUF-BRUCE-F14S1G3
6 Membri
4 guide realizzate
1Commento della guida
Hello is this about replacing the memory card compartment or just the memory card? Apparently the memory card compartment is not maintining the memory, it’s not keeping it in the memor slot keeps popping back up. How do I fix this? Can I replace the housing?
Joseph Antonio - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 17
Ultimi 30 giorni: 57
Tutti i Tempi: 5,496
