Salta al contenuto principale
Nikon Coolpix S51c LCD Screen Replacement
Cosa ti serve
  1. Nikon Coolpix S51c LCD Screen Replacement, Back Cover: passo 1, immagine 1 di 2 Nikon Coolpix S51c LCD Screen Replacement, Back Cover: passo 1, immagine 2 di 2
    • First, use a Phillips #00 screwdriver to remove all five screws that are located at the bottom of the camera.
  2. Nikon Coolpix S51c LCD Screen Replacement: passo 2, immagine 1 di 1
    • Next, slide the battery door open in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using the Phillips #00 screwdriver.
  3. Nikon Coolpix S51c LCD Screen Replacement: passo 3, immagine 1 di 1
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
  4. Nikon Coolpix S51c LCD Screen Replacement: passo 4, immagine 1 di 1
    • Lift the back cover.
    • Be careful not to rip the orange cables between the camera and the back cover.
  5. Nikon Coolpix S51c LCD Screen Replacement: passo 5, immagine 1 di 1
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger.
    • Carefully remove the back cover.
  6. Nikon Coolpix S51c LCD Screen Replacement, LCD Screen: passo 6, immagine 1 di 1
    • On back of LCD screen, locate the three screws underneath the ribbon.
    • Remove each screw using your screwdriver.
  7. Nikon Coolpix S51c LCD Screen Replacement: passo 7, immagine 1 di 2 Nikon Coolpix S51c LCD Screen Replacement: passo 7, immagine 2 di 2
    • Take out the rectangular component on the side where the screws were.
    • Carefully, pry apart the screen from the back casing using the spudger.
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Ryan
Membro da: 04/12/11
167 Reputazione
6 Guide realizzate
Cal Poly, Team 18-24, Garner Spring 2011 Membro di Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,702
