Introduzione
This guide showcases how to replace the back casing on a Nikon COOLPX p7700 camera. By following these seven simple steps, you should comfortably be able to remove the casing on the camera to get to the inside.
Cosa ti serve
Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
Remove the side panel.
Altre 2 persone hanno completato questa guida.
