Salta al contenuto principale
Nexus Q LED Board Replacement
Cosa ti serve
    1. Nexus Q LED Board Replacement, Ball Bearing Ring: passo 1, immagine 1 di 1
      • Squeeze and pull the cap to remove it from the Nexus Q.
      Chiedi a FixBot
      Aggiungi Commento
    2. Nexus Q LED Board Replacement: passo 2, immagine 1 di 1
      • Use a spudger to disconnect the Taoglas Wi-Fi Dual Band Antenna.
      Chiedi a FixBot
      Aggiungi Commento
    3. Nexus Q LED Board Replacement: passo 3, immagine 1 di 1
      • Undo the ZIF connector by prying it with a spudger.
      Chiedi a FixBot
      Aggiungi Commento
    4. Nexus Q LED Board Replacement: passo 4, immagine 1 di 1
      • Use a Phillips #0 screwdriver to unscrew the four 1.3 mm screws.
      • After removing the screws, there will be two parts. The top part contains the daughterboard. Store it safely. It will not be used.
      Chiedi a FixBot
      Aggiungi Commento
    5. Nexus Q LED Board Replacement: passo 5, immagine 1 di 1
      • View the bottom half of the Nexus Q.
      • Use a Phillips #0 screwdriver to remove the four 0.8 mm screws holding the ball bearing ring in place.
      Chiedi a FixBot
      Aggiungi Commento
    6. Nexus Q LED Board Replacement: passo 6, immagine 1 di 1
      • Remove the ball bearing ring.
      • When placing a new ring in its place, make sure to orient it right or the top will not close.
      Chiedi a FixBot
      Aggiungi Commento
    1. Nexus Q LED Board Replacement, LED Board: passo 7, immagine 1 di 2 Nexus Q LED Board Replacement, LED Board: passo 7, immagine 2 di 2
      • Once you remove the ball bearing ring from the bottom half of the Nexus Q, you will be exposed to a diffuser (white ring) held in with three T6 Torx screws.
      • Use a #0 Philips head screwdriver to remove the three 0.8 mm screws holding the diffuser in place.
      Chiedi a FixBot
      Aggiungi Commento
    2. Nexus Q LED Board Replacement: passo 8, immagine 1 di 2 Nexus Q LED Board Replacement: passo 8, immagine 2 di 2
      • With the diffuser out, we are exposed to the LED Board.
      • Use a spudger to lightly lift the LED board out.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Taewan Kim
Membro da: 01/31/13
22 Reputazione
2 guide realizzate
Cal Poly, Team 7-10, Maness Winter 2013 Membro di Cal Poly, Team 7-10, Maness Winter 2013
CPSU-MANESS-W13S7G10
4 Membri
15 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 27
Tutti i Tempi: 851
