Salta al contenuto principale
Network Card
Cosa ti serve
    1. Network Card, Bottom Cover: passo 1, immagine 1 di 1
      • Use a Philips J1 driver to remove eight screws securing the bottom case.
      • Remove all of the 8 screws and the bottom panel should pop off.
      Chiedi a FixBot
      Aggiungi Commento
    2. Network Card: passo 2, immagine 1 di 1
      • After that you are in and now can change most of the components, which we also have tutorials for.
      Chiedi a FixBot
      Aggiungi Commento
    1. Network Card, Network Card: passo 3, immagine 1 di 1
      • Remove the screw with a Philips J1 driver.
      • Try to remove the cables by hand or if you really can't, then use a spudger to carefully pry them up.
      • After removing the screw and the cables, you can safely remove the network card.
      Chiedi a FixBot
      Aggiungi Commento
    2. Network Card: passo 4, immagine 1 di 1
      • If you need to change the Wireless card and nothing else then now is the time to do so.
      • After the previous step, you are good to go.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Regome
Membro da: 01/20/23
866 Reputazione
7 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 22
Tutti i Tempi: 363
