Salta al contenuto principale
Netgear Arlo 2 Camera HD Security System Case Replacement
Cosa ti serve
    1. Netgear Arlo 2 Camera HD Security System Case Replacement, Case: passo 1, immagine 1 di 3 Netgear Arlo 2 Camera HD Security System Case Replacement, Case: passo 1, immagine 2 di 3 Netgear Arlo 2 Camera HD Security System Case Replacement, Case: passo 1, immagine 3 di 3
      • Unscrew the two 3.0 mm Phillips #00 screws on the bottom of the camera.
      • Open the battery compartment on the bottom by pushing the switch marked in orange to the side and pushing the bottom of the camera back, sliding it open.
      Chiedi a FixBot
      Aggiungi Commento
    2. Netgear Arlo 2 Camera HD Security System Case Replacement: passo 2, immagine 1 di 2 Netgear Arlo 2 Camera HD Security System Case Replacement: passo 2, immagine 2 di 2
      • Remove the bottom piece of the case over the battery compartment by placing a plastic opening tool underneath the edge of the case and prying it up.
      • Unscrew the four 3.0 mm Phillips #00 screws on the outside of the battery pocket.
      Chiedi a FixBot
      Aggiungi Commento
    3. Netgear Arlo 2 Camera HD Security System Case Replacement: passo 3, immagine 1 di 2 Netgear Arlo 2 Camera HD Security System Case Replacement: passo 3, immagine 2 di 2
      • When facing the camera lens, the left panel of the case will be removed first (more steps are needed for the right panel).
      • Place the plastic opening tool between the two pieces of the case and pry them apart from the bottom.
      • Gently pull the side of the case off as it comes loose.
      Chiedi a FixBot
      Aggiungi Commento
    4. Netgear Arlo 2 Camera HD Security System Case Replacement: passo 4, immagine 1 di 2 Netgear Arlo 2 Camera HD Security System Case Replacement: passo 4, immagine 2 di 2
      • Unscrew the smaller 3.0 mm Phillips #00 screw in the center on the back of the device.
      • Flip the camera over and unscrew the center 3.0 mm Phillips #00 screw above the SYNC button.
      Chiedi a FixBot
      Aggiungi Commento
    5. Netgear Arlo 2 Camera HD Security System Case Replacement: passo 5, immagine 1 di 2 Netgear Arlo 2 Camera HD Security System Case Replacement: passo 5, immagine 2 di 2
      • Using the plastic opening tool, gently pry the right panel from the device.
      • Replace either side of the plastic case as needed.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 16
Ultimi 30 giorni: 49
Tutti i Tempi: 2,153
