Introduzione
This guide will explain the process of removing and replacing the internal camera of the device. This is one of 3 guides that will handle electrical connections so it is best to be very gentle when doing so. To best use this guide the Phillips 00 screwdriver is recommended. The Phillips 000 or 0 may work as well, please note that the smaller the screwdriver the higher chances of stripping the screw. It is also recommended to have a plastic opening tool (blue) to gently pull the device apart and a bowl or container to keep the small and easily lost screws in.
Cosa ti serve
Unscrew the two 3.0 mm Phillips #00 screws on the bottom of the camera.
Open the battery compartment on the bottom by pushing the switch marked in orange to the side and pushing the bottom of the camera back, sliding it open.
Unscrew the four 4.0 mm Phillips #00 screws on either side of the transparent case.
Separate the transparent half of the case from the white half.
Repeat the same process as in Step 6 to release the flat ribbon cable from the black rectangular latch
Unscrew the six black 3.0 mm Phillips #00 screws that hold the black motherboard on.
Release the clip at the bottom left corner of the black motherboard by pinching the wings at either side of the clip.
