Salta al contenuto principale
Nest x Yale Lock Motherboard Replacement
Cosa ti serve
  1. Nest x Yale Lock Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Before proceeding, make sure the batteries are removed to avoid being electrocuted and damage to the lock
    • If you do not know how to remove the batteries then I would recommend looking at our battery replacement guide for help.
  2. Nest x Yale Lock Motherboard Replacement: passo 2, immagine 1 di 2 Nest x Yale Lock Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove 3 screws as shown to remove the first cover.
    • The 3 screws are 0.25 inches length
  3. Nest x Yale Lock Motherboard Replacement: passo 3, immagine 1 di 1
    • Using a pin to push down the knot holding the wire and the tweezer to safely remove the wire from the motherboard
  4. Nest x Yale Lock Motherboard Replacement: passo 4, immagine 1 di 2 Nest x Yale Lock Motherboard Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a spudger or plastic tool to lift the ZIF lock upward (as shown in the first picture).
    • Use tweezers to remove the ribbon cable from the motherboard.
  5. Nest x Yale Lock Motherboard Replacement: passo 5, immagine 1 di 1
    • Continue to remove 2 screws holding the motherboard to the lock shell.
    • The screws are 0.20 inches in length.
  6. Nest x Yale Lock Motherboard Replacement: passo 6, immagine 1 di 2 Nest x Yale Lock Motherboard Replacement: passo 6, immagine 2 di 2
    • Use an opening tool to push the motherboard out as shown in the picture.
Conclusione
Bryant Duong
Membro da: 09/26/22
379 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 392
