Salta al contenuto principale
Nest x Yale Lock Deadbolt Button Replacement
Cosa ti serve
  1. Nest x Yale Lock Deadbolt Button Replacement, Motherboard: passo 1, immagine 1 di 1
    • Before proceeding, make sure the batteries are removed to avoid being electrocuted and damage to the lock
    • If you do not know how to remove the batteries then I would recommend looking at our battery replacement guide for help.
  2. Nest x Yale Lock Deadbolt Button Replacement: passo 2, immagine 1 di 2 Nest x Yale Lock Deadbolt Button Replacement: passo 2, immagine 2 di 2
    • Remove 3 screws as shown to remove the first cover.
    • The 3 screws are 0.25 inches length
  3. Nest x Yale Lock Deadbolt Button Replacement: passo 3, immagine 1 di 1
    • Using a pin to push down the knot holding the wire and the tweezer to safely remove the wire from the motherboard
  4. Nest x Yale Lock Deadbolt Button Replacement: passo 4, immagine 1 di 2 Nest x Yale Lock Deadbolt Button Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a spudger or plastic tool to lift the ZIF lock upward (as shown in the first picture).
    • Use tweezers to remove the ribbon cable from the motherboard.
  5. Nest x Yale Lock Deadbolt Button Replacement: passo 5, immagine 1 di 1
    • Continue to remove 2 screws holding the motherboard to the lock shell.
    • The screws are 0.20 inches in length.
  6. Nest x Yale Lock Deadbolt Button Replacement: passo 6, immagine 1 di 2 Nest x Yale Lock Deadbolt Button Replacement: passo 6, immagine 2 di 2
    • Use an opening tool to push the motherboard out as shown in the picture.
  7. Nest x Yale Lock Deadbolt Button Replacement, Deadbolt Button: passo 7, immagine 1 di 2 Nest x Yale Lock Deadbolt Button Replacement, Deadbolt Button: passo 7, immagine 2 di 2
    • After, fully removing the motherboard.
    • Remove the .25 in screws circled in red to remove the lock compartment.
    • Lastly, take out the lock as shown in the second picture.
  8. Nest x Yale Lock Deadbolt Button Replacement: passo 8, immagine 1 di 1
    • Move onto removing the .25 inches screws in red to take out the battery holder.
    • Remove the .15 inches screws in orange as well.
  9. Nest x Yale Lock Deadbolt Button Replacement: passo 9, immagine 1 di 2 Nest x Yale Lock Deadbolt Button Replacement: passo 9, immagine 2 di 2
    • After unscrewing the battery holder you can now see the lights circled in red
    • The part squared in orange is a rubber that reflects the light of the LED.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 439
