Salta al contenuto principale
Nerf Recon CS-6 O-Ring Replacement
Cosa ti serve
  1. Nerf Recon CS-6 O-Ring Replacement, Remove Magazine: passo 1, immagine 1 di 1
    • Skip this step if magazine is already removed.
    • Pull slide back.
    • Pull backwards on release buttons and slide magazine out.
    • Push slide back forward and pull trigger.
    My priming bar is stuck how do I fix this?
    Ethan - Replica
  2. Nerf Recon CS-6 O-Ring Replacement, Remove Visible Screws: passo 2, immagine 1 di 1
    • Use the Phillips #0 Screwdriver to remove these 9 screws.
    • All screws marked in red are 9.6 mm Phillips #0 screws.
    • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
  3. Nerf Recon CS-6 O-Ring Replacement, Remove Hidden Screws: passo 3, immagine 1 di 2 Nerf Recon CS-6 O-Ring Replacement, Remove Hidden Screws: passo 3, immagine 2 di 2
    • Pull slide back to reveal more screws.
    • Remove these 2 screws.
    • Push slide forward.
    • Pull trigger to release compression of the main spring.
    • Screws are 9.6 mm Phillips #0.
    • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
    Lost the trigger spring. What spec of spring can I replace it with?
    derekpearcy - Replica
  4. Nerf Recon CS-6 O-Ring Replacement, Remove Plunger Cap: passo 4, immagine 1 di 1
    • Remove the screws on the plunger cap.
    • Tug the plunger cap off.
  5. Nerf Recon CS-6 O-Ring Replacement, Remove Slide Screws: passo 5, immagine 1 di 1
    • Remove the 2 screws on the slide.
    • Hold the two halves of the gun together to prevent any springs from launching out.
  6. Nerf Recon CS-6 O-Ring Replacement, Split the Gun in Half: passo 6, immagine 1 di 2 Nerf Recon CS-6 O-Ring Replacement, Split the Gun in Half: passo 6, immagine 2 di 2
    • Pull the gun apart at the middle seam.
    • Watch for any springs that might launch out.
    Pay attention to the orientation of the tabs on the compression tube. The tabs fit into grooves on the side of the gun. This tripped me up.
    Bob - Replica
  7. Nerf Recon CS-6 O-Ring Replacement, Remove Spring: passo 7, immagine 1 di 2 Nerf Recon CS-6 O-Ring Replacement, Remove Spring: passo 7, immagine 2 di 2
    • Pull the spring out the back of the gun.
  8. Nerf Recon CS-6 O-Ring Replacement, Removing Plunger Guide: passo 8, immagine 1 di 1
    • Lift the plunger guide straight up out of the gun.
  9. Nerf Recon CS-6 O-Ring Replacement, Remove Plunger: passo 9, immagine 1 di 1
    • Pull the plunger out the back of the gun off of the inner piece.
  10. Nerf Recon CS-6 O-Ring Replacement, Remove  Other Half of Plunger: passo 10, immagine 1 di 1
    • Pull the remaining half of the plunger out the back of the gun.
    Hi, do you know where is the place that I can purchase the plunger?
    mohd-fairuz - Replica
  11. Nerf Recon CS-6 O-Ring Replacement, Removing O-Ring: passo 11, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to lift the O-Ring out of groove.
    • Replace with new O-Ring.
    • Optional: add a small amount of a lubricant safe for the O-Ring such as petroleum jelly.
Conclusione
Pam Ruffner
Membro da: 10/20/14
1.002 Reputazione
3 Guide realizzate
Baylor, Team 8-14, Williams Fall 2014 Membro di Baylor, Team 8-14, Williams Fall 2014
BU-WILLIAMS-F14S8G14
3 Membri
6 Guide realizzate
Un commento
Ace Hardware 1/16x13/16x1/16 #37 R-80 O-Ring fits
Mr.H - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,475
