Salta al contenuto principale
Nerf Recon CS-6 Main Spring Replacement
Cosa ti serve
    1. Nerf Recon CS-6 Main Spring Replacement, Remove Magazine: passo 1, immagine 1 di 1
      • Skip this step if magazine is already removed.
      • Pull slide back.
      • Pull backwards on release buttons and slide magazine out.
      • Push slide back forward and pull trigger.
      Chiedi a FixBot
      Aggiungi Commento
    2. Nerf Recon CS-6 Main Spring Replacement, Remove Visible Screws: passo 2, immagine 1 di 1
      • Use the Phillips #0 Screwdriver to remove these 9 screws.
      • All screws marked in red are 9.6 mm Phillips #0 screws.
      • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
      Chiedi a FixBot
      Aggiungi Commento
    3. Nerf Recon CS-6 Main Spring Replacement, Remove Hidden Screws: passo 3, immagine 1 di 2 Nerf Recon CS-6 Main Spring Replacement, Remove Hidden Screws: passo 3, immagine 2 di 2
      • Pull slide back to reveal more screws.
      • Remove these 2 screws.
      • Push slide forward.
      • Pull trigger to release compression of the main spring.
      • Screws are 9.6 mm Phillips #0.
      • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
      Chiedi a FixBot
      Aggiungi Commento
    4. Nerf Recon CS-6 Main Spring Replacement, Remove Plunger Cap: passo 4, immagine 1 di 1
      • Remove the screws on the plunger cap.
      • Tug the plunger cap off.
      Chiedi a FixBot
      Aggiungi Commento
    5. Nerf Recon CS-6 Main Spring Replacement, Remove Slide Screws: passo 5, immagine 1 di 1
      • Remove the 2 screws on the slide.
      • Hold the two halves of the gun together to prevent any springs from launching out.
      Chiedi a FixBot
      Aggiungi Commento
    6. Nerf Recon CS-6 Main Spring Replacement, Split the Gun in Half: passo 6, immagine 1 di 2 Nerf Recon CS-6 Main Spring Replacement, Split the Gun in Half: passo 6, immagine 2 di 2
      • Pull the gun apart at the middle seam.
      • Watch for any springs that might launch out.
      Chiedi a FixBot
      Aggiungi Commento
    1. Nerf Recon CS-6 Main Spring Replacement, Remove Spring: passo 7, immagine 1 di 2 Nerf Recon CS-6 Main Spring Replacement, Remove Spring: passo 7, immagine 2 di 2
      • Pull the spring out the back of the gun.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 8 persone hanno completato questa guida.
Baylor, Team 8-14, Williams Fall 2014 Membro di Baylor, Team 8-14, Williams Fall 2014
BU-WILLIAMS-F14S8G14
3 Membri
6 guide realizzate
1Commento della guida
Where can you buy replacement springs from?
Tom Hallam - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 36
Tutti i Tempi: 6,593
