Salta al contenuto principale
Nerf N-Strike Firestrike LED Replacement
Cosa ti serve
    1. Nerf N-Strike Firestrike LED Replacement, Blaster Casing: passo 1, immagine 1 di 1
      • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Nerf N-Strike Firestrike LED Replacement: passo 2, immagine 1 di 2 Nerf N-Strike Firestrike LED Replacement: passo 2, immagine 2 di 2
      • Slowly pull apart the blaster casing, starting at the battery location.
      • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
      Chiedi a FixBot
      Aggiungi Commento
    3. Nerf N-Strike Firestrike LED Replacement: passo 3, immagine 1 di 2 Nerf N-Strike Firestrike LED Replacement: passo 3, immagine 2 di 2
      • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
      • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
      • For reassembly, note the location of the springs as highlighted in the second photo.
      Chiedi a FixBot
      Aggiungi Commento
    1. Nerf N-Strike Firestrike LED Replacement, Remove battery cover: passo 4, immagine 1 di 1
      • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
      Chiedi a FixBot
      Aggiungi Commento
    2. Nerf N-Strike Firestrike LED Replacement: passo 5, immagine 1 di 2 Nerf N-Strike Firestrike LED Replacement: passo 5, immagine 2 di 2
      • Slide out the two AAA batteries using your fingers.
      Chiedi a FixBot
      Aggiungi Commento
    1. Nerf N-Strike Firestrike LED Replacement, Laser Trigger: passo 6, immagine 1 di 2 Nerf N-Strike Firestrike LED Replacement, Laser Trigger: passo 6, immagine 2 di 2
      • Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
      Chiedi a FixBot
      Aggiungi Commento
    1. Nerf N-Strike Firestrike LED Replacement, Laser Assembly: passo 7, immagine 1 di 1
      • Gently pull up on the circuit board located near the gun handle until it separates from the gun.
      • The wire that attaches to the circuit board is also attached to the laser. Be careful not to use excessive force and damage or disconnect the wire.
      Chiedi a FixBot
      Aggiungi Commento
    2. Nerf N-Strike Firestrike LED Replacement: passo 8, immagine 1 di 3 Nerf N-Strike Firestrike LED Replacement: passo 8, immagine 2 di 3 Nerf N-Strike Firestrike LED Replacement: passo 8, immagine 3 di 3
      • Grip the circuit board located at the base of the laser with your fingers; rotate it towards the ammo compartment on the blaster until the guide hole is clear of the guide pin.
      • Slide the laser assembly out.
      Chiedi a FixBot
      Aggiungi Commento
    1. Nerf N-Strike Firestrike LED Replacement, LED: passo 9, immagine 1 di 2 Nerf N-Strike Firestrike LED Replacement, LED: passo 9, immagine 2 di 2
      • Pinch the clips holding the laser beam casing to the circuit board with your fingers. Slide off the casing revealing the LED.
      Chiedi a FixBot
      Aggiungi Commento
    2. Nerf N-Strike Firestrike LED Replacement: passo 10, immagine 1 di 1
      • Use a soldering iron to heat up the two connections holding the LED to the circuit board. Remove the LED.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team 15-6, Amido Spring 2015 Membro di Cal Poly, Team 15-6, Amido Spring 2015
CPSU-AMIDO-S15S15G6
3 Membri
8 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 39
Tutti i Tempi: 3,591
