Salta al contenuto principale
Nerf N-Strike Elite Retaliator Trigger Spring Replacement
Cosa ti serve
  1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Case Disassembly: passo 1, immagine 1 di 1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
    Chiedi a FixBot
    Aggiungi Commento
  2. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: passo 2, immagine 1 di 1
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
    Chiedi a FixBot
    Aggiungi Commento
  3. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: passo 3, immagine 1 di 1
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
    Chiedi a FixBot
    Aggiungi Commento
  4. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: passo 4, immagine 1 di 2 Nerf N-Strike Elite Retaliator Trigger Spring Replacement: passo 4, immagine 2 di 2
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
    Chiedi a FixBot
    Aggiungi Commento
  5. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: passo 5, immagine 1 di 2 Nerf N-Strike Elite Retaliator Trigger Spring Replacement: passo 5, immagine 2 di 2
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
    Chiedi a FixBot
    Aggiungi Commento
  6. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: passo 6, immagine 1 di 3 Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: passo 6, immagine 2 di 3 Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: passo 6, immagine 3 di 3
    • Carefully pull the orange trigger upward and backward to remove it from the blaster.
    • This component is under spring pressure. Wear appropriate personal protective equipment to shield your eyes.
    • Remove the spring from the rear of the trigger.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
ericharman
Membro da: 03/02/16
1.440 Reputazione
5 guide realizzate
1Commento della guida
ok, taken the spring out. now what?
Kelvin Mead - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 31
Tutti i Tempi: 10,122
