Introduzione
Find out how to change the battery in your Mpow 059 Headphones. The battery is located in the left ear cup and is simple to replace. This repair may be necessary if your batteries are no longer working and it may affect the noise cancellation, signal transmission, and audio drivers.
Note: If possible, make sure your battery is completely depleted before replacing it. If a lithium-ion battery is punctured during replacement, it may spark and create a fire.
Cosa ti serve
Place the iFixit opening tool between the soft ear cushion and the hard plastic of the speaker.
Pry the soft ear cushion away from the hard plastic using a moderate amount of pressure.
Use the Phillips #1 screwdriver to remove the six screws holding the red plastic cover in place.
Carefully peel the plastic cover off the left cup to reveal the ear cup's internal components.
Altre 7 persone hanno completato questa guida.
8Commenti sulla guida
Hello
What kind of glue should I use to put new pad?
What is the part number for the replacement battery? Where can I find one?
First, you need to pry the piece behind the R headphone, which is itself adhered. THEN you need to pry the battery off of the backing.
And finally, you can realize you did all of this for nothing if you don't know how to solder. The battery cables are soldered onto the chip, making it impossible to replace without soldering in the replacement wires.
