Salta al contenuto principale
Motorola i710 Keypad Sensor Replacement
  1. Motorola i710 Keypad Sensor Replacement, Battery Cover: passo 1, immagine 1 di 2 Motorola i710 Keypad Sensor Replacement, Battery Cover: passo 1, immagine 2 di 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
    Chiedi a FixBot
    Aggiungi Commento
  2. Motorola i710 Keypad Sensor Replacement, Battery: passo 2, immagine 1 di 1
    • Push the battery towards the top of the phone and lift up.
    Chiedi a FixBot
    Aggiungi Commento
  3. Motorola i710 Keypad Sensor Replacement, Motherboard: passo 3, immagine 1 di 3 Motorola i710 Keypad Sensor Replacement, Motherboard: passo 3, immagine 2 di 3 Motorola i710 Keypad Sensor Replacement, Motherboard: passo 3, immagine 3 di 3
    • Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
    • Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
    • The motherboard should now be completely disconnected from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  4. Motorola i710 Keypad Sensor Replacement, Keypad Sensor: passo 4, immagine 1 di 2 Motorola i710 Keypad Sensor Replacement, Keypad Sensor: passo 4, immagine 2 di 2
    • Once the motherboard has been removed from the keypad, the keypad sensor can be detached from the phone at the hinge.
    • Gently pry off the cable connecting the keypad sensor. The keypad sensor should now be completely separated from the phone.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Katelyn
Membro da: 10/22/12
1 Reputazione
2 guide realizzate
Clemson, Team 14-2, Benson Fall 2012 Membro di Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Membri
29 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 30
Tutti i Tempi: 622
