Salta al contenuto principale
Motorola V710 Camera Replacement
Cosa ti serve
  1. Motorola V710 Camera Replacement, Screen: passo 1, immagine 1 di 3 Motorola V710 Camera Replacement, Screen: passo 1, immagine 2 di 3 Motorola V710 Camera Replacement, Screen: passo 1, immagine 3 di 3
    • Insert the spudger between the gray and black plates of the screen casing.
    • Using a twist and pry motion work your way around the phone slowly prying the two plates apart.
    • Note: this part of the phone is glued and will require re-gluing to return the phone to its original state.
    Chiedi a FixBot
    Aggiungi Commento
  2. Motorola V710 Camera Replacement: passo 2, immagine 1 di 2 Motorola V710 Camera Replacement: passo 2, immagine 2 di 2
    • If you look at the side of the now exposed screen there should be a metal casing held onto the phone by two tabs.
    • Insert the spudger underneath one of the corners of the metal and bend it out enough to slip it over the tabs.
    • This metal is reasonably resistant to bending and will likely require a good deal of force to get it off the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. Motorola V710 Camera Replacement: passo 3, immagine 1 di 2 Motorola V710 Camera Replacement: passo 3, immagine 2 di 2
    • Orient the phone so that the main screen is facing upward.
    • Locate the hinge casing, a dark gray piece that covers the hinge.
    • Insert the spudger under one of the top corners of this piece and using a twist and pry motion remove from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  4. Motorola V710 Camera Replacement: passo 4, immagine 1 di 2 Motorola V710 Camera Replacement: passo 4, immagine 2 di 2
    • Use the spudger to pry upward and remove the plug that connects the screen to the main body of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  5. Motorola V710 Camera Replacement: passo 5, immagine 1 di 2 Motorola V710 Camera Replacement: passo 5, immagine 2 di 2
    • Insert the spudger under the screen and pry the screen forward.
    • Remove the plug on the back of the screen that connects it to the camera.
    Chiedi a FixBot
    Aggiungi Commento
  6. Motorola V710 Camera Replacement: passo 6, immagine 1 di 2 Motorola V710 Camera Replacement: passo 6, immagine 2 di 2
    • Use the spudger to remove the screen.
    Chiedi a FixBot
    Aggiungi Commento
  7. Motorola V710 Camera Replacement, Camera: passo 7, immagine 1 di 3 Motorola V710 Camera Replacement, Camera: passo 7, immagine 2 di 3 Motorola V710 Camera Replacement, Camera: passo 7, immagine 3 di 3
    • Use the spudger to remove the camera module.
    • Note: The camera has an adhesive holding it in place, so a slight force is necessary to remove it.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 8-49, Regan Winter 2010 Membro di Cal Poly, Team 8-49, Regan Winter 2010
CPSU-REGAN-W10S8G49
5 Membri
24 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 5
Ultimi 30 giorni: 34
Tutti i Tempi: 1,937
