Salta al contenuto principale
Motorola V60s Button Key Pad Replacement
Cosa ti serve
  1. Motorola V60s Button Key Pad Replacement, Battery: passo 1, immagine 1 di 3 Motorola V60s Button Key Pad Replacement, Battery: passo 1, immagine 2 di 3 Motorola V60s Button Key Pad Replacement, Battery: passo 1, immagine 3 di 3
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
    Chiedi a FixBot
    Aggiungi Commento
  2. Motorola V60s Button Key Pad Replacement: passo 2, immagine 1 di 2 Motorola V60s Button Key Pad Replacement: passo 2, immagine 2 di 2
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
    Chiedi a FixBot
    Aggiungi Commento
  3. Motorola V60s Button Key Pad Replacement, Motherboard: passo 3, immagine 1 di 2 Motorola V60s Button Key Pad Replacement, Motherboard: passo 3, immagine 2 di 2
    • Remove the four corner screws with a T6 screwdriver.
    • The two top screws are short and silver. The two bottom screws are black and long.
    Chiedi a FixBot
    Aggiungi Commento
  4. Motorola V60s Button Key Pad Replacement: passo 4, immagine 1 di 3 Motorola V60s Button Key Pad Replacement: passo 4, immagine 2 di 3 Motorola V60s Button Key Pad Replacement: passo 4, immagine 3 di 3
    • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
    Chiedi a FixBot
    Aggiungi Commento
  5. Motorola V60s Button Key Pad Replacement: passo 5, immagine 1 di 3 Motorola V60s Button Key Pad Replacement: passo 5, immagine 2 di 3 Motorola V60s Button Key Pad Replacement: passo 5, immagine 3 di 3
    • Starting from left side of phone, remove side buttons and place aside.
    • There are three buttons. One on each side, and the top.
    • Return phone to starting orientation when done.
    Chiedi a FixBot
    Aggiungi Commento
  6. Motorola V60s Button Key Pad Replacement: passo 6, immagine 1 di 3 Motorola V60s Button Key Pad Replacement: passo 6, immagine 2 di 3 Motorola V60s Button Key Pad Replacement: passo 6, immagine 3 di 3
    • Gently remove orange ribbon cable by prying up with spudger.
    Chiedi a FixBot
    Aggiungi Commento
  7. Motorola V60s Button Key Pad Replacement: passo 7, immagine 1 di 2 Motorola V60s Button Key Pad Replacement: passo 7, immagine 2 di 2
    • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
    • Orange ribbon cable is fragile and can be broken.
    Chiedi a FixBot
    Aggiungi Commento
  8. Motorola V60s Button Key Pad Replacement, Button Key Board: passo 8, immagine 1 di 2 Motorola V60s Button Key Pad Replacement, Button Key Board: passo 8, immagine 2 di 2
    • Insert an opening tool under the button board and gently lift.
    Chiedi a FixBot
    Aggiungi Commento
  9. Motorola V60s Button Key Pad Replacement, Button Key Pad: passo 9, immagine 1 di 2 Motorola V60s Button Key Pad Replacement, Button Key Pad: passo 9, immagine 2 di 2
    • Life button keypad with spudger and set aside.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 8-48, Regan Winter 2010 Membro di Cal Poly, Team 8-48, Regan Winter 2010
CPSU-REGAN-W10S8G48
4 Membri
20 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 28
Tutti i Tempi: 3,310
