Introduzione
Follow this guide to replace a cracked or damaged screen on the Motorola Moto E5.
This guide requires the removal of the battery. We recommend not re-using the old battery, as removing it can deform it slightly and potentially cause safety issues if you re-use it. Replace the battery along with the screen.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Use a SIM eject bit, SIM eject tool, or paper clip to remove the SIM card from the phone.
Prepare an iOpener and heat the back of the phone along one edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the back cover to the phone.
Remove the following Phillips screws securing the fingerprint sensor cable cover:
One 1.6 mm screw.
One 3.8 mm screw.
Remove the back cover.
Repair didn’t go as planned? Check out our Motorola Moto E5 Answers community for troubleshooting help.
Altre 3 persone hanno completato questa guida.
