Introduzione
You've tried to turn your phone off for work, but the power button is stuck. Fortunately, with this guide, you can fix this problem and have control over your phone's life again.
Cosa ti serve
Remove the two 4.5mm screws in the bottom left and right corners of the device using a T4 Torx Screwdriver.
Lift up the screen further to reveal another cable at the top of the device connecting the motherboard to the screen.
Use tweezers to lift the black bar on top of the ZIF connector.
Pull the ribbon cable out of the connector with tweezers.
Now that there are no cables connecting the screen to the motherboard, remove the screen.
Strumento utilizzato in questo passaggio:Tweezers$4.99
Remove the two 3.5mm Torx T4 screws securing the rear facing camera.
Using tweezers, remove the metal shield protecting the rear facing camera.
Remove the two 3.5mm Torx T4 screws securing the headphone jack cable/cover.
Using tweezers, disconnect the headphone jack cable/cover and remove it. The headphone jack will stay where it is.
Use a plastic opening tool to lift up the battery from the frame of the device.
Remove the battery.
Remove the three 3.5mm Torx T3 screws holding the power/volume button cable to the side of the frame.
Altre 5 persone hanno completato questa guida.
