Salta al contenuto principale
Motorola Droid Pro Camera Replacement
Cosa ti serve
  1. Motorola Droid Pro Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back cover using the thumb tab located on the bottom of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. Motorola Droid Pro Camera Replacement: passo 2, immagine 1 di 2 Motorola Droid Pro Camera Replacement: passo 2, immagine 2 di 2
    • Remove the battery using the thumb tab.
    Chiedi a FixBot
    Aggiungi Commento
  3. Motorola Droid Pro Camera Replacement, SD Card/SIM Card PCB Board: passo 3, immagine 1 di 2 Motorola Droid Pro Camera Replacement, SD Card/SIM Card PCB Board: passo 3, immagine 2 di 2
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
    Chiedi a FixBot
    Aggiungi Commento
  4. Motorola Droid Pro Camera Replacement: passo 4, immagine 1 di 3 Motorola Droid Pro Camera Replacement: passo 4, immagine 2 di 3 Motorola Droid Pro Camera Replacement: passo 4, immagine 3 di 3
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
    Chiedi a FixBot
    Aggiungi Commento
  5. Motorola Droid Pro Camera Replacement: passo 5, immagine 1 di 2 Motorola Droid Pro Camera Replacement: passo 5, immagine 2 di 2
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
    Chiedi a FixBot
    Aggiungi Commento
  6. Motorola Droid Pro Camera Replacement, Motherboard: passo 6, immagine 1 di 2 Motorola Droid Pro Camera Replacement, Motherboard: passo 6, immagine 2 di 2
    • Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
    • There are small tabs on the side of the connectors to wedge your tool under.
    Chiedi a FixBot
    Aggiungi Commento
  7. Motorola Droid Pro Camera Replacement: passo 7, immagine 1 di 2 Motorola Droid Pro Camera Replacement: passo 7, immagine 2 di 2
    • Use your plastic opening tool to disconnect the two ribbon cables at the top of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  8. Motorola Droid Pro Camera Replacement: passo 8, immagine 1 di 2 Motorola Droid Pro Camera Replacement: passo 8, immagine 2 di 2
    • Disconnect the 2nd keyboard connector from the motherboard and remove it from its side holders.
    • This cable is fragile so be careful when disconnecting and moving it around.
    Chiedi a FixBot
    Aggiungi Commento
  9. Motorola Droid Pro Camera Replacement: passo 9, immagine 1 di 1
    • Use a T5 Torx Screwdriver to unscrew the 2mm screw.
    Chiedi a FixBot
    Aggiungi Commento
  10. Motorola Droid Pro Camera Replacement: passo 10, immagine 1 di 3 Motorola Droid Pro Camera Replacement: passo 10, immagine 2 di 3 Motorola Droid Pro Camera Replacement: passo 10, immagine 3 di 3
    • Remove the camera's rubber seal by pulling it off. It is not connected to anything.
    Chiedi a FixBot
    Aggiungi Commento
  11. Motorola Droid Pro Camera Replacement: passo 11, immagine 1 di 2 Motorola Droid Pro Camera Replacement: passo 11, immagine 2 di 2
    • To remove the motherboard, pull it to the side. The camera that is connected to the motherboard does not pull straight up and out from its holder.
    Chiedi a FixBot
    Aggiungi Commento
  12. Motorola Droid Pro Camera Replacement, Camera: passo 12, immagine 1 di 3 Motorola Droid Pro Camera Replacement, Camera: passo 12, immagine 2 di 3 Motorola Droid Pro Camera Replacement, Camera: passo 12, immagine 3 di 3
    • The camera is located on the back side of PCB board.
    • Flip the board over and you will see that the camera is connected by a ribbon cable.
    • Unlock the cable by using a plastic remover tool then pull the camera out.
    • Insert the new camera and re lock the ribbon cable.
    • Do not use excessive force and make sure the cameras ribbon cable gets properly re seated.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
UMass Dartmouth, Team 1-6, Miles Fall 2015 Membro di UMass Dartmouth, Team 1-6, Miles Fall 2015
UMASSD-MILES-F15S1G6
3 Membri
18 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 20
Tutti i Tempi: 405
