Salta al contenuto principale
Motorola Defy XT Screen Replacement
Cosa ti serve
  1. Motorola Defy XT Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
    Chiedi a FixBot
    Aggiungi Commento
  2. Motorola Defy XT Screen Replacement: passo 2, immagine 1 di 1
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
    Chiedi a FixBot
    Aggiungi Commento
  3. Motorola Defy XT Screen Replacement: passo 3, immagine 1 di 1
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
    Chiedi a FixBot
    Aggiungi Commento
  4. Motorola Defy XT Screen Replacement, SD Card: passo 4, immagine 1 di 1
    • Open the plastic cover with your finger, exposing the SD card.
    • Use the opening tool to grab the edge of the SD card and pull it straight out.
    Chiedi a FixBot
    Aggiungi Commento
  5. Motorola Defy XT Screen Replacement, Screen: passo 5, immagine 1 di 2 Motorola Defy XT Screen Replacement, Screen: passo 5, immagine 2 di 2
    • Use the Torx T4 screwdriver to remove the six 3 mm screws from the back case.
    Chiedi a FixBot
    Aggiungi Commento
  6. Motorola Defy XT Screen Replacement: passo 6, immagine 1 di 1
    • Use the plastic opening tool to pop the volume buttons off from the side of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  7. Motorola Defy XT Screen Replacement: passo 7, immagine 1 di 1
    • Wedge the plastic opening tool between the plastic layer and the shiny front cover.
    Chiedi a FixBot
    Aggiungi Commento
  8. Motorola Defy XT Screen Replacement: passo 8, immagine 1 di 1
    • Slide the plastic opening tool along the edge, wedging the the two pieces apart.
    • Potential for device damage: Do not completely separate the two pieces; there are still internal components that need to be disconnected.
    Chiedi a FixBot
    Aggiungi Commento
  9. Motorola Defy XT Screen Replacement: passo 9, immagine 1 di 2 Motorola Defy XT Screen Replacement: passo 9, immagine 2 di 2
    • Slide the screen out and disconnect the ribbon cable connecting the display to the motherboard by pulling straight outward.
    • Potential for device damage: Be careful when sliding out the screen because the front case and the motherboard are still connected by two other ribbon cables.
    Chiedi a FixBot
    Aggiungi Commento
  10. Motorola Defy XT Screen Replacement: passo 10, immagine 1 di 2 Motorola Defy XT Screen Replacement: passo 10, immagine 2 di 2
    • Set the old screen aside and replace it with your new screen.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 2-22, Maness Spring 2013 Membro di Cal Poly, Team 2-22, Maness Spring 2013
CPSU-MANESS-S13S2G22
3 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 44
Tutti i Tempi: 3,620
