Salta al contenuto principale
Motorola Defy XT Battery Replacement
Cosa ti serve
  1. Motorola Defy XT Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Wedge the plastic opening tool in between the back cover and the body of the phone in the opening denoted by the arrow.
    Chiedi a FixBot
    Aggiungi Commento
  2. Motorola Defy XT Battery Replacement: passo 2, immagine 1 di 1
    • Once wedged in the opening, slide the opening tool sideways around the sides of the phone.
    • Remove the back cover and set it aside.
    Chiedi a FixBot
    Aggiungi Commento
  3. Motorola Defy XT Battery Replacement: passo 3, immagine 1 di 1
    • Insert the opening tool between the battery and the battery holder and wedge the battery out.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 2-22, Maness Spring 2013 Membro di Cal Poly, Team 2-22, Maness Spring 2013
CPSU-MANESS-S13S2G22
3 Membri
16 guide realizzate
1Commento della guida
There isn't really much need for guidance on replacing the battery, but it would be helpful if you could provide some details on how long it takes for the first charge after replacement. I connected my charger after replacing the battery and it only lights up the back/menu/home keys below the screen - no indication of battery charging etc. and the phone cannot be powered yet. It's been charging for well over half an hour. Any advice?
shaunschon - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 36
Tutti i Tempi: 2,155
