Salta al contenuto principale
Motorola Cliq Camera Replacement
Cosa ti serve
  1. Motorola Cliq Camera Replacement, Battery: passo 1, immagine 1 di 2 Motorola Cliq Camera Replacement, Battery: passo 1, immagine 2 di 2
    • Turning over your phone, place two fingers on the back cover and apply pressure away from the camera to slide the back cover off.
    Chiedi a FixBot
    Aggiungi Commento
  2. Motorola Cliq Camera Replacement: passo 2, immagine 1 di 2 Motorola Cliq Camera Replacement: passo 2, immagine 2 di 2
    • Pinch the battery pull tab located below the camera, pull it upwards, and remove the battery.
    • The pull tab may be tucked under the battery.
    Chiedi a FixBot
    Aggiungi Commento
  3. Motorola Cliq Camera Replacement, Rear Casing: passo 3, immagine 1 di 3 Motorola Cliq Camera Replacement, Rear Casing: passo 3, immagine 2 di 3 Motorola Cliq Camera Replacement, Rear Casing: passo 3, immagine 3 di 3
    • Wedge a plastic opening tool behind the panel covering the camera, pry it up, and remove it using your fingers.
    • The panel is held down by adhesive and may require you to wedge and pry the right side of the panel before it can be easily removed.
    Chiedi a FixBot
    Aggiungi Commento
  4. Motorola Cliq Camera Replacement: passo 4, immagine 1 di 1
    • Remove the six 4.0 mm T4 Torx screws which line the edge of the back of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  5. Motorola Cliq Camera Replacement: passo 5, immagine 1 di 3 Motorola Cliq Camera Replacement: passo 5, immagine 2 di 3 Motorola Cliq Camera Replacement: passo 5, immagine 3 di 3
    • Turn the phone over and slide out the keyboard.
    • Wedge a plastic opening tool where the keyboard meets the back casing of the phone next to the headphone jack.
    • Carefully pry open the back casing along the keyboard's edge until at least two corners of the back casing are separated from the keyboard.
    • Do not fully separate the rear panel from the phone. A cable is connecting the two parts together.
    Chiedi a FixBot
    Aggiungi Commento
  6. Motorola Cliq Camera Replacement: passo 6, immagine 1 di 1
    • Carefully separate the back casing from the rest of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  7. Motorola Cliq Camera Replacement: passo 7, immagine 1 di 2 Motorola Cliq Camera Replacement: passo 7, immagine 2 di 2
    • Gently pry ZIF connector upwards using the flat end of a spudger tool.
    • The ZIF connector is glued down. Be gentle! Ripping it off or breaking it will make your phone inoperable.
    • You may need adhesive to keep your power cable in place when reassembling your phone.
    Chiedi a FixBot
    Aggiungi Commento
  8. Motorola Cliq Camera Replacement: passo 8, immagine 1 di 3 Motorola Cliq Camera Replacement: passo 8, immagine 2 di 3 Motorola Cliq Camera Replacement: passo 8, immagine 3 di 3
    • Press your thumb against the orange power cable and pull it down slowly to disconnect the power cable from the bottom of the keyboard.
    • The rear casing and the rest of the phone should now be completely separated.
    Chiedi a FixBot
    Aggiungi Commento
  9. Motorola Cliq Camera Replacement, Camera: passo 9, immagine 1 di 3 Motorola Cliq Camera Replacement, Camera: passo 9, immagine 2 di 3 Motorola Cliq Camera Replacement, Camera: passo 9, immagine 3 di 3
    • Insert a 1.5mm flat head screw in the slit in between the camera housing and the bottom of the camera.
    • Lightly pry upwards and the camera should come loose from the housing.
    Chiedi a FixBot
    Aggiungi Commento
  10. Motorola Cliq Camera Replacement: passo 10, immagine 1 di 3 Motorola Cliq Camera Replacement: passo 10, immagine 2 di 3 Motorola Cliq Camera Replacement: passo 10, immagine 3 di 3
    • Carefully grab the sides of the camera with your fingers and remove the camera.
    • The foam cover on the top of the camera deforms and tears easily, so handle it with care.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 10-42, Amido Spring 2013 Membro di Cal Poly, Team 10-42, Amido Spring 2013
CPSU-AMIDO-S13S10G42
4 Membri
24 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 41
Tutti i Tempi: 717
