Introduzione
If the front camera on your Moto G4 is no longer working, follow this step by step guide to replace it yourself.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Cosa ti serve
Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
Gently twist or pry to open a small gap between the back cover and the body of the phone.
While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
Insert a thin tool (such as one of your tweezer tips) under the red and black battery wires, and slide it underneath the battery connector.
Gently pry straight up to disconnect the battery.
Use your spudger to pry up the front-facing camera and make sure it separates safely from the frame.
Peel back and remove any tape covering the front-facing camera's flex cable connector.
Pry up with your spudger or other ESD-safe tool to flip open the locking flap on the front-facing camera's ZIF connector.
Gently pull the camera's flex cable free from the ZIF socket.
