Salta al contenuto principale
Model O- Mouse Cable Replacement
Cosa ti serve
    1. Model O- Mouse Cable Replacement, Mouse Cable: passo 1, immagine 1 di 3 Model O- Mouse Cable Replacement, Mouse Cable: passo 1, immagine 2 di 3 Model O- Mouse Cable Replacement, Mouse Cable: passo 1, immagine 3 di 3
      Strumento utilizzato in questo passaggio:
      • Turn the mouse over so that the feet are facing you.
      • Remove the bottom two mouse feet using tweezers.
      • If you plan on reusing the mouse feet place them with the adhesive side up.
      Chiedi a FixBot
      Aggiungi Commento
    2. Model O- Mouse Cable Replacement: passo 2, immagine 1 di 2 Model O- Mouse Cable Replacement: passo 2, immagine 2 di 2
      • Using a Phillips #0 screwdriver, remove the two screws that are under the mouse feet.
      Chiedi a FixBot
      Aggiungi Commento
    3. Model O- Mouse Cable Replacement: passo 3, immagine 1 di 3 Model O- Mouse Cable Replacement: passo 3, immagine 2 di 3 Model O- Mouse Cable Replacement: passo 3, immagine 3 di 3
      • Slide the base away from the top housing to avoid the front clips.
      • Lift the top and place it down diagonal over the base, exposing the 5-pin connector.
      • Avoid putting strain on the thin LED ribbon cables.
      Chiedi a FixBot
      Aggiungi Commento
    4. Model O- Mouse Cable Replacement: passo 4, immagine 1 di 2 Model O- Mouse Cable Replacement: passo 4, immagine 2 di 2
      • Use two fingers to grasp the top of the 5-pin connector under the edges and slowly lift the connector. If it is difficult, wiggle the plug slightly.
      • Do not pull on the wires.
      • Remove the cable from around the circuit board and from the hole on the front of the mouse.
      Chiedi a FixBot
      Aggiungi Commento
    5. Model O- Mouse Cable Replacement: passo 5, immagine 1 di 2 Model O- Mouse Cable Replacement: passo 5, immagine 2 di 2
      • Insert the new cable's 5-pin connector plug (red) into the 5-pin connector socket (orange).
      • Do not push on the wires.
      Chiedi a FixBot
      Aggiungi Commento
    6. Model O- Mouse Cable Replacement: passo 6, immagine 1 di 2 Model O- Mouse Cable Replacement: passo 6, immagine 2 di 2
      • Route the new cable through the slit in the circuit board.
      • Route the new cable behind the pillars.
      • Route the cable through the hole at the front of the mouse. Some cables have a fitted square plastic piece that positions the cable, some have thermoplastic which requires the user to position it themselves.
      • The cable may not stay in place until the top housing is securely fastened back on.
      Chiedi a FixBot
      Aggiungi Commento
    7. Model O- Mouse Cable Replacement: passo 7, immagine 1 di 2 Model O- Mouse Cable Replacement: passo 7, immagine 2 di 2
      • Join the top and bottom housing together with the top around 1cm ahead of the bottom, then pull the top housing back as illustrated.
      • Once the two sides of the shell are together apply pressure until at least one screw is securely fastening them together.
      Chiedi a FixBot
      Aggiungi Commento
    8. Model O- Mouse Cable Replacement: passo 8, immagine 1 di 1
      • Screw the two screws back in with a Phillips #0 screwdriver.
      • Do not apply too much force or you risk stripping the screw holes.
      Chiedi a FixBot
      Aggiungi Commento
    9. Model O- Mouse Cable Replacement: passo 9, immagine 1 di 2 Model O- Mouse Cable Replacement: passo 9, immagine 2 di 2
      • Reapply the mouse feet with the adhesive side sticking to the mouse.
      • There are plastic ridges to help guide the user where to place the mouse feet.
      • Certain mouse cables come with new mouse feet which can be applied here instead of reapplying the old feet.
      Chiedi a FixBot
      Aggiungi Commento
Linea Traguardo
Altre 4 persone hanno completato questa guida.
Theo SW
Membro da: 01/22/21
265 Reputazione
Una guida realizzata
2Commenti sulla guida
Where can I get the replacement cable for it?
Ekke Sten - Rispondi Condividi
does glorius them selfs sell replacment parts ?
aniss-97 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 24
Ultimi 30 giorni: 81
Tutti i Tempi: 14,233
