Salta al contenuto principale
Minolta Dimage Xt Capture Button Replacement
Cosa ti serve
    1. Minolta Dimage Xt Capture Button Replacement, Casing: passo 1, immagine 1 di 3 Minolta Dimage Xt Capture Button Replacement, Casing: passo 1, immagine 2 di 3 Minolta Dimage Xt Capture Button Replacement, Casing: passo 1, immagine 3 di 3
      • Locate and remove the silver screws on each side of the camera.
      • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
      Chiedi a FixBot
      Aggiungi Commento
    2. Minolta Dimage Xt Capture Button Replacement: passo 2, immagine 1 di 3 Minolta Dimage Xt Capture Button Replacement: passo 2, immagine 2 di 3 Minolta Dimage Xt Capture Button Replacement: passo 2, immagine 3 di 3
      • Then, carefully pry apart the front and back outer casing away from the internal components.
      • Be aware of the ribbon wire that will disconnect when the casing is detached.
      Chiedi a FixBot
      Aggiungi Commento
    1. Minolta Dimage Xt Capture Button Replacement, Capture Button: passo 3, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      • Choosing the front half of the casing, locate the capture button on the top.
      • Using tweezers, apply pressure to the two black hooks (circled in red) while holding the button down from the outside of the case.
      Chiedi a FixBot
      Aggiungi Commento
    2. Minolta Dimage Xt Capture Button Replacement: passo 4, immagine 1 di 1
      • The button will spring free. The capture device consists of the plastic button and a small metal spring.
      • The button can be reassembled by using the tweezers to place the spring rectangle-side down on the button and snapping the button back into place.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Reassemble the casing by reversing steps 1 and 2.
Clemson, Team 12-4, Benson Spring 2013 Membro di Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Membri
14 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 36
Tutti i Tempi: 961
