Salta al contenuto principale
Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement
Cosa ti serve
  1. Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement, Outer Casing: passo 1, immagine 1 di 1
    • Remove each of the seven 14mm Pan Hd. T-10 ST screws on one side of the housing assembly using the T10 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  2. Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement: passo 2, immagine 1 di 1
    • Remove metal clip located at the base of the drill, where the battery is to be inserted.
    • You may need to use a spudger if the clip is too difficult to remove with your fingers.
    Chiedi a FixBot
    Aggiungi Commento
  3. Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement, Forward/Reverse Shuttle: passo 3, immagine 1 di 3 Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement, Forward/Reverse Shuttle: passo 3, immagine 2 di 3 Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement, Forward/Reverse Shuttle: passo 3, immagine 3 di 3
    • Use both hands to lift and remove the gear case assembly from the shell casing.
    • Set the gear case assembly aside.
    Chiedi a FixBot
    Aggiungi Commento
  4. Milwaukee M12 2407-20 Forward/Reverse Shuttle Replacement: passo 4, immagine 1 di 1
    • While holding the shell in one hand, pull the end of the broken forward/reverse shuttle out of the casing.
    • Set the broken forward/reverse shuttle aside.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 30
Tutti i Tempi: 2,393
