Salta al contenuto principale
Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement
Cosa ti serve
  1. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement, Thumbstick Covers: passo 1, immagine 1 di 3 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement, Thumbstick Covers: passo 1, immagine 2 di 3 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement, Thumbstick Covers: passo 1, immagine 3 di 3
    • Remove the battery pack cover.
    • If there are any batteries inside of it, remove them.
  2. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: passo 2, immagine 1 di 3 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: passo 2, immagine 2 di 3 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: passo 2, immagine 3 di 3
    • Place an iFixit opening tool between the seam of both the front and side plates.
    • Move the tool repeatedly along the seam between the two plates until the side plate is wholly disconnected from the front plate.
  3. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: passo 3, immagine 1 di 3 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: passo 3, immagine 2 di 3 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: passo 3, immagine 3 di 3
    • Remove or pick a hole on the warranty sticker label to reveal the center screw.
    • Remove all five screws from the backplate using a TR8 Torx screwdriver.
  4. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: passo 4, immagine 1 di 3 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: passo 4, immagine 2 di 3 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: passo 4, immagine 3 di 3
    • Remove the front plate from the controller.
  5. Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: passo 5, immagine 1 di 3 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: passo 5, immagine 2 di 3 Microsoft Xbox Series X Pulse Controller Thumbstick Cover Replacement: passo 5, immagine 3 di 3
    • Pop-out the old thumbsticks and connect the new thumbsticks to the joystick.
Conclusione
Altre 16 persone hanno completato questa guida.
Edgar Galindo
Membro da: 03/20/22
509 Reputazione
1 Guida realizzata
4 Commenti
Does this method fix joystick drift?
Aaron - Replica
@aaron73239 , to fix the joystick drift, you might want to try this guide.
Kris Rodriguez -
Where is the article addressing stick-drift/replacement, if this is not it?
Pictory - Replica
Perhaps it is this article? Xbox One Wireless Controller Model 1708 Button Replacement
Would be appreciated if someone with relevant knowledge or experience would confirm this.
Pictory -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 94
Ultimi 30 Giorni: 392
Tutti i Tempi: 26,812
