Salta al contenuto principale
Microsoft Surface Pro Kickstand Replacement
Cosa ti serve
  1. Microsoft Surface Pro Kickstand Replacement, Kickstand: passo 1, immagine 1 di 1
    • Turn the tablet so the back is facing up.
    • Lift the kickstand to access the screws.
    • Remove the two T5 Torx screws:
    • One from the left hinge
    • One from the right hinge
    Chiedi a FixBot
    Aggiungi Commento
  2. Microsoft Surface Pro Kickstand Replacement: passo 2, immagine 1 di 1
    • To remove the kickstand, gently pull up until the three tabs slide out of the slots on the back of the device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 12 persone hanno completato questa guida.
Mark
Membro da: 10/09/13
764 Reputazione
Una guida realizzata
Cal Poly, Team 8-20, Regan Fall 2013 Membro di Cal Poly, Team 8-20, Regan Fall 2013
CPSU-REGAN-F13S8G20
4 Membri
16 guide realizzate
1Commento della guida
I had trouble getting the center tab to slide out of the slot. After looking at the other tabs, which came out easily, I noticed that the tabs are not composed of a single piece but are actually two sheets glued together (like two pieces of tape). Somehow the two pieces of tape composing the center tab had come apart, exposing their adhesive surfaces, and sticking to an inner surface. I managed to push them apart enough from the outside with a flathead screwdriver so that I could slide the center tab out. However, the other piece is stuck inside the device.
artlives13 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 27
Ultimi 7 giorni: 45
Ultimi 30 giorni: 131
Tutti i Tempi: 41,149
