Salta al contenuto principale
Microsoft Band Battery Replacement
Cosa ti serve
    1. Microsoft Band Battery Replacement, Battery: passo 1, immagine 1 di 1
      • Unscrew both side panel 2mm screws using the T3 Torx screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Microsoft Band Battery Replacement: passo 2, immagine 1 di 1
      • Firmly pry up the side panel using the plastic spudger to break the waterproof seal and lift the battery panel.
      Chiedi a FixBot
      Aggiungi Commento
    3. Microsoft Band Battery Replacement: passo 3, immagine 1 di 1
      • Gently pry up one edge of the battery with the plastic spudger.
      Chiedi a FixBot
      Aggiungi Commento
    4. Microsoft Band Battery Replacement: passo 4, immagine 1 di 1
      • Remove battery from its compartment with your fingers.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in reverse order. Replace the vibrator in its original compartment.
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 17-34, Amido Winter 2015 Membro di Cal Poly, Team 17-34, Amido Winter 2015
CPSU-AMIDO-W15S17G34
4 Membri
6 guide realizzate
5Commenti sulla guida
where can i buy the battery?
chirac - Rispondi Condividi
From what I can tell it's something like this:
http://www.alibaba.com/product-detail/Ho...
which is a 3.7v flat lithium ion polymer 72mAh battery. Min order is 1030 though! You can find similar on AliExpress if you search for that description. The dimensions are listed as 4*14.8*21.5mm so it'll need to be within that, or maybe the OP can confirm the battery size?
Simon - Rispondi Condividi
Will this be dangerous?
Rei zzstu Shiozawa - Rispondi Condividi
Anyway to upgrade to a higher capacity battery to get better life out of it? With GPS on, it dies in 2 hours and I go on 8 hr hikes.
Chris Green - Rispondi Condividi
No tak wszystko fajnie ale gdzie te akumulatory zakupić ?
Tomasz Sot - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 14
Ultimi 30 giorni: 54
Tutti i Tempi: 12,580
