Salta al contenuto principale
Mayflash Arcade Stick F300 Microswitch Replacement
Cosa ti serve
  1. Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: passo 1, immagine 1 di 3 Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: passo 1, immagine 2 di 3 Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: passo 1, immagine 3 di 3
    • Flip the controller upside down so that the metal panel is facing you.
    • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
    • Once all screws are removed, lift off the panel.
    Chiedi a FixBot
    Aggiungi Commento
  2. Mayflash Arcade Stick F300 Microswitch Replacement, Microswitch: passo 2, immagine 1 di 2 Mayflash Arcade Stick F300 Microswitch Replacement, Microswitch: passo 2, immagine 2 di 2
    • Remove the four 9 mm truss head screws fastening the clear plastic square joystick gate to the casing underneath using a Phillips #1 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  3. Mayflash Arcade Stick F300 Microswitch Replacement: passo 3, immagine 1 di 3 Mayflash Arcade Stick F300 Microswitch Replacement: passo 3, immagine 2 di 3 Mayflash Arcade Stick F300 Microswitch Replacement: passo 3, immagine 3 di 3
    • Gently push back on each of the four black locking tabs securing the joystick gate to the casing.
    • Remove the joystick gate.
    Chiedi a FixBot
    Aggiungi Commento
  4. Mayflash Arcade Stick F300 Microswitch Replacement: passo 4, immagine 1 di 2 Mayflash Arcade Stick F300 Microswitch Replacement: passo 4, immagine 2 di 2
    • Lift the chosen microswitch vertically off the rod holding it in position.
    • Desolder the wire from the terminal (metal connection point).
    • Beware of overheating the soldering kit as it can damage electronic components.
    • Use a wire stripper or small blade to strip the insulation approximately 1 cm from the end of the wire before resoldering to the new part.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 21
Ultimi 30 giorni: 51
Tutti i Tempi: 482
