Salta al contenuto principale
Marshall Emberton Button Replacement
Cosa ti serve
  1. Marshall Emberton Button Replacement, Button: passo 1, immagine 1 di 1
    • Remove the rubber casing from the speaker by peeling it off using your nails.
    Chiedi a FixBot
    Aggiungi Commento
  2. Marshall Emberton Button Replacement: passo 2, immagine 1 di 1
    • Use a TR9 screwdriver to remove the eight 1 cm screws located on top of the speaker.
    Chiedi a FixBot
    Aggiungi Commento
  3. Marshall Emberton Button Replacement: passo 3, immagine 1 di 1
    • Once all the screws are off, you must pry the plastic piece off using any tool capable of sliding into the crevice. Then easily pop the piece out.
    Chiedi a FixBot
    Aggiungi Commento
  4. Marshall Emberton Button Replacement: passo 4, immagine 1 di 1
    • On the back side of the plastic piece, there is a circuit which is shown in the picture. Use a TR9 screwdriver to remove two 1.2 cm screws to detach the circuit from the plastic housing.
    Chiedi a FixBot
    Aggiungi Commento
  5. Marshall Emberton Button Replacement: passo 5, immagine 1 di 1
    • Once the circuit is removed, you may gently pop the button off and easily replace it with a new one.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
4Commenti sulla guida
where can i find a replacement button
MANU 1907 - Rispondi Condividi
The worst instruction I've ever seen in my life. If you do this, you will break your device.
cool eo - Rispondi Condividi
yes, i confirme !!!
Mallet Jp - Rispondi Condividi
@cooleo fortunately i figured it out but yeah you ned to disassemble multiple parts. disassemble from the front panel (marshal logo panel is pressure fit, undo the phillips, and take the board out behind it, and then take out the top out + switch.
Daniel Hyunsu Kim - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 59
Ultimi 30 giorni: 215
Tutti i Tempi: 4,356
