Salta al contenuto principale
Managing Texas Instruments TI-92 Keyboard
Cosa ti serve
  1. Managing Texas Instruments TI-92 Keyboard, Back Cover: passo 1, immagine 1 di 3 Managing Texas Instruments TI-92 Keyboard, Back Cover: passo 1, immagine 2 di 3 Managing Texas Instruments TI-92 Keyboard, Back Cover: passo 1, immagine 3 di 3
    • The first step to any repair operation is to remove the front cover.
    • Grab the back of the calculator with one hand and the cover with the other.
    • Pull the cover off from one of the sides for easy removal.
    Chiedi a FixBot
    Aggiungi Commento
  2. Managing Texas Instruments TI-92 Keyboard: passo 2, immagine 1 di 2 Managing Texas Instruments TI-92 Keyboard: passo 2, immagine 2 di 2
    • Orientate the calculator with the top facing towards you.
    • Slide the locking tab,found on the top part of the calculator, to the unlock position.
    Chiedi a FixBot
    Aggiungi Commento
  3. Managing Texas Instruments TI-92 Keyboard: passo 3, immagine 1 di 2 Managing Texas Instruments TI-92 Keyboard: passo 3, immagine 2 di 2
    • "Locking Tab"
    • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
    • Then with the front of the calculator facing down, pull up on the back cover.
    • The calculator should now be orientated with the front facing down, as shown in picture 2.
    Chiedi a FixBot
    Aggiungi Commento
  4. Managing Texas Instruments TI-92 Keyboard, Batteries: passo 4, immagine 1 di 3 Managing Texas Instruments TI-92 Keyboard, Batteries: passo 4, immagine 2 di 3 Managing Texas Instruments TI-92 Keyboard, Batteries: passo 4, immagine 3 di 3
    • The Batteries are now exposed and the calculator is face down with the back towards you.
    • Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
    • If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
    • After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
    • Now simply remove the battery.
    Chiedi a FixBot
    Aggiungi Commento
  5. Managing Texas Instruments TI-92 Keyboard, Texas Instruments TI-92 Back Case Disassembly: passo 5, immagine 1 di 3 Managing Texas Instruments TI-92 Keyboard, Texas Instruments TI-92 Back Case Disassembly: passo 5, immagine 2 di 3 Managing Texas Instruments TI-92 Keyboard, Texas Instruments TI-92 Back Case Disassembly: passo 5, immagine 3 di 3
    • Using a Philips Screwdriver #00 unscrew the twelve 11.8mm screws shown in the picture and located on the back of the calculator.
    Chiedi a FixBot
    Aggiungi Commento
  6. Managing Texas Instruments TI-92 Keyboard: passo 6, immagine 1 di 1
    • Unscrew the 19mm screw located near center of the back of the calculator.
    • Remove the panel being held by the screw.
    Chiedi a FixBot
    Aggiungi Commento
  7. Managing Texas Instruments TI-92 Keyboard: passo 7, immagine 1 di 1
    • Using the same Phillips screwdriver, unscrew the remaining three 11.8mm screws.
    Chiedi a FixBot
    Aggiungi Commento
  8. Managing Texas Instruments TI-92 Keyboard: passo 8, immagine 1 di 2 Managing Texas Instruments TI-92 Keyboard: passo 8, immagine 2 di 2
    • Using the Ipod Opening Tool pull up on both sides of the rectangular module while keeping the rest of the calculator flat on a surface face down
    • You may get a lot of resistance from the module. Do not use too much force as you risk damage. Use small amounts of force to work the module out.
    Chiedi a FixBot
    Aggiungi Commento
  9. Managing Texas Instruments TI-92 Keyboard: passo 9, immagine 1 di 2 Managing Texas Instruments TI-92 Keyboard: passo 9, immagine 2 di 2
    • Pull out the rectangular module when it is finally loose enough.
    Chiedi a FixBot
    Aggiungi Commento
  10. Managing Texas Instruments TI-92 Keyboard: passo 10, immagine 1 di 2 Managing Texas Instruments TI-92 Keyboard: passo 10, immagine 2 di 2
    • Now pull up on the back cover of the calculator while holding the rest of it flat on a surface.
    • Be careful not to tilt the front of the calculator at this point. The keyboard buttons are now unsupported and will fall out of place.
    Chiedi a FixBot
    Aggiungi Commento
  11. Managing Texas Instruments TI-92 Keyboard, Keyboard: passo 11, immagine 1 di 2 Managing Texas Instruments TI-92 Keyboard, Keyboard: passo 11, immagine 2 di 2
    • Here we will use the front panel, separate from the motherboard
    • Make sure not to tilt this part unless you want to remove all the keys from the face plate.
    • Remove the rubber contact lying on top of the keys.
    Chiedi a FixBot
    Aggiungi Commento
  12. Managing Texas Instruments TI-92 Keyboard: passo 12, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • With the rubber contact removed the keys can now be removed to be replaced, cleaned, or manipulated in other ways.
    • To aid the removal of individual keys you can use the Ipod Opening Tool or preferably a pair of tweezers.
    Chiedi a FixBot
    Aggiungi Commento
  13. Managing Texas Instruments TI-92 Keyboard: passo 13, immagine 1 di 3 Managing Texas Instruments TI-92 Keyboard: passo 13, immagine 2 di 3 Managing Texas Instruments TI-92 Keyboard: passo 13, immagine 3 di 3
    • When placing the keys back into the faceplate you have to make sure that they are going in the right direction.
    • You can tell which way is up by a semicircular extrusion on the back of a key.
    • The gray and blue keys have the extrusion on the upper left hole looking at the back of the key.
    • The black keys on the other hand have the extrusions on the lower left hole looking at the back of the key.
    Chiedi a FixBot
    Aggiungi Commento
  14. Managing Texas Instruments TI-92 Keyboard: passo 14, immagine 1 di 3 Managing Texas Instruments TI-92 Keyboard: passo 14, immagine 2 di 3 Managing Texas Instruments TI-92 Keyboard: passo 14, immagine 3 di 3
    • Use the pictures shown here as guides for where the keys should go if the keys fell out or you simply chose to remove them.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 15-51, Garner Spring 2010 Membro di Cal Poly, Team 15-51, Garner Spring 2010
CPSU-GARNER-S10S15G51
5 Membri
18 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 12
Ultimi 30 giorni: 34
Tutti i Tempi: 3,033
