Salta al contenuto principale
Main Click Buttons
Cosa ti serve
    1. Main Click Buttons, Click Buttons: passo 1, immagine 1 di 2 Main Click Buttons, Click Buttons: passo 1, immagine 2 di 2
      • Use a blue spudger to pry all 4 mouse feet off the bottom of the mouse.
      Chiedi a FixBot
      Aggiungi Commento
    2. Main Click Buttons: passo 2, immagine 1 di 2 Main Click Buttons: passo 2, immagine 2 di 2
      • Use a #00 screwdriver (3x5mm) to unscrew all 6 screws from under the mouse feet.
      Chiedi a FixBot
      Aggiungi Commento
    3. Main Click Buttons: passo 3, immagine 1 di 2 Main Click Buttons: passo 3, immagine 2 di 2
      • Use a blue spudger to open the bottom battery port.
      Chiedi a FixBot
      Aggiungi Commento
    4. Main Click Buttons: passo 4, immagine 1 di 2 Main Click Buttons: passo 4, immagine 2 di 2
      • Lift the top of the mouse from the base of the mouse (separate mouse in half) to expose the internal hardware.
      Chiedi a FixBot
      Aggiungi Commento
    5. Main Click Buttons: passo 5, immagine 1 di 3 Main Click Buttons: passo 5, immagine 2 di 3 Main Click Buttons: passo 5, immagine 3 di 3
      • Use pliers to grip and remove the black covers over the button — the black cover and the button, a small white plastic piece, should come off).
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 18 persone hanno completato questa guida.
6Commenti sulla guida
how are you supposed to put the feet back?
Owen Yuen - Rispondi Condividi
you have to buy new ones… i’m more concerned of using pliers to take the switch apart, when ideally you should desolder it and replace it with a proper omron switch (not made in china)
Erick Alonso Duque - Rispondi Condividi
He is only removing the cover, not the whole button. But doing it with pliers is skipping that it has two clips, one at each end and you could damage the board just twisting and pulling
Russell Reeling - Rispondi Condividi
Are the side buttons the same?
S I - Rispondi Condividi
What do you do after step 5? And that copper spring looks wrong. It shouldn’t look like that. The correct positioning is this: https://community.pcgamingwiki.com/galle...
Nonalbert Noneinstein - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 31
Ultimi 30 giorni: 190
Tutti i Tempi: 25,760
