Salta al contenuto principale
Magic Bullet NutriBullet Outside Casing Replacement
Cosa ti serve
    1. Magic Bullet NutriBullet Outside Casing Replacement, Curve Base: passo 1, immagine 1 di 1
      • Unplug the device from the wall and turn the powerbase upside down.
      Chiedi a FixBot
      Aggiungi Commento
    2. Magic Bullet NutriBullet Outside Casing Replacement: passo 2, immagine 1 di 2 Magic Bullet NutriBullet Outside Casing Replacement: passo 2, immagine 2 di 2
      • Use a #2 Phillips Head Screwdriver to unscrew the four 10 mm screws located on the bottom of the power base.
      Chiedi a FixBot
      Aggiungi Commento
    3. Magic Bullet NutriBullet Outside Casing Replacement: passo 3, immagine 1 di 1
      • Use slight tension to remove the plastic base from the NutriBullet once all of the screws are removed.
      • When reassembling, note the fan located in the center of the powerbase. Make sure the cord does not get caught or frayed by the fan.
      Chiedi a FixBot
      Aggiungi Commento
    4. Magic Bullet NutriBullet Outside Casing Replacement: passo 4, immagine 1 di 1
      • Lift the power cord to remove it from the side slot on the curved base.
      Chiedi a FixBot
      Aggiungi Commento
    5. Magic Bullet NutriBullet Outside Casing Replacement: passo 5, immagine 1 di 2 Magic Bullet NutriBullet Outside Casing Replacement: passo 5, immagine 2 di 2
      • Use a #2 Phillips Head Screwdriver to remove the two 10 mm screws that secure the white bracket down.
      • The white safety bracket holds the cord down. After removing it, the cord will be loosened.
      Chiedi a FixBot
      Aggiungi Commento
    6. Magic Bullet NutriBullet Outside Casing Replacement: passo 6, immagine 1 di 1
      • Use a #2 Phillips Head Screwdriver to remove the three 10mm screws that keep the base in place.
      Chiedi a FixBot
      Aggiungi Commento
    7. Magic Bullet NutriBullet Outside Casing Replacement: passo 7, immagine 1 di 1
      • Use slight tension to remove the curved base by lifting it upward off of the outside casing.
      Chiedi a FixBot
      Aggiungi Commento
    1. Magic Bullet NutriBullet Outside Casing Replacement, Outside Casing: passo 8, immagine 1 di 1
      • Wiggle the outside casing upward until it separates from the powerbase.
      • Hold the ring at the bottom of the powerbase to receive a better grip.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Angela Wong
Membro da: 01/22/15
1.177 Reputazione
3 guide realizzate
Cal Poly, Team 19-8, Maness Winter 2015 Membro di Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Membri
19 guide realizzate
4Commenti sulla guida
Ok so what happens after Step 8 of pulling the Nutribullet apart? Did I miss something?? Now I have my Nutribullet in pieces on the benchtop. Now what??
Nicole Corse-Scott - Rispondi Condividi
Same problem. I can't get the drive gear on the top loose which I assume will actual give me access to the wiring. I am guessing it is a pressure fit but I can't get anything under it to pry it loose. If it is a screw attachment don't want to break it. Help.
rjurgena - Rispondi Condividi
So what happens next? What is one suppose to do? Stupid help, I would say
Mary Johnson - Rispondi Condividi
I tried step number 8 and the outside casing still won't slide off. What do I do now?
Euclid Taylor - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 15
Ultimi 30 giorni: 73
Tutti i Tempi: 8,771
