Salta al contenuto principale
MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement
Cosa ti serve
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  2. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 3, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 3, immagine 2 di 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  3. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement, Battery Connector: passo 4, immagine 1 di 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  4. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 5, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 5, immagine 2 di 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  5. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 6, immagine 1 di 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  6. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement, Right Speaker: passo 7, immagine 1 di 1
    • Remove the two 2.1 mm T5 Torx screws securing the logic board end of the I/O board cable bracket.
  7. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 8, immagine 1 di 1
    • Grasp the I/O board cable bracket with a pair of tweezers and remove it from the MacBook.
  8. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 9, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 9, immagine 2 di 2
    • Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
    • Be careful to only pry up on the I/O board cable, not on the socket itself or you risk damaging your logic board.
  9. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 10, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 10, immagine 2 di 2
    • Lift the logic board end of the I/O board cable straight up to bend it out of the way.
    • To avoid damage to the cable, fold only at the bend in the I/O board end of the cable.
  10. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 11, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 11, immagine 2 di 2
    • Carefully tuck the tip of a spudger under the right speaker cable near the connector and lift it up out of its socket on the logic board.
  11. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 12, immagine 1 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 12, immagine 2 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 12, immagine 3 di 3
    • Carefully peel the right speaker cable off the upper case.
  12. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 13, immagine 1 di 1
    • Remove the following screws securing the right speaker to the upper case:
    • One 5.7 mm T5 Torx screw
    • One 6.5 mm T5 Torx screw
    • One 3.8 mm T5 Torx screw
  13. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 14, immagine 1 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 14, immagine 2 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 14, immagine 3 di 3
    • Lift the right speaker from the cable end and pull it free from the case.
  14. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement, iOpener Heating: passo 15, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement, iOpener Heating: passo 15, immagine 2 di 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  15. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 16, immagine 1 di 1
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  16. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 17, immagine 1 di 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  17. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement, Alternate iOpener heating method: passo 18, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement, Alternate iOpener heating method: passo 18, immagine 2 di 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  18. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement, Battery: passo 19, immagine 1 di 1
    • Remove the five 3.7 mm T5 Torx screws securing the battery to the upper case.
    • Your specific unit may only have one screw securing the battery's circuit board to the frame.
  19. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 20, immagine 1 di 1
    • The liquid adhesive remover provided in your iFixit battery replacement kit can affect the antireflective coating on your MacBook Pro's display.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
  20. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 21, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 21, immagine 2 di 2
    • If you have an iFixit battery kit with liquid adhesive remover, it's time to get it prepped.
    • Alternatively, if you are using the hot iOpener method, skip the following three steps.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
  21. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 22, immagine 1 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 22, immagine 2 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 22, immagine 3 di 3
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
  22. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 23, immagine 1 di 1
    • Apply a few drops of adhesive remover evenly under the edge of the rightmost battery cell.
    • You don't need to use very much. The small bottle contains more than twice the amount of solvent needed to remove all the battery cells.
    • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
    • Use more adhesive remover if needed, but do not apply more than a few drops at a time. Using too much can allow the adhesive remover to make its way to the backside of your keyboard and potentially damage it.
  23. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 24, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 24, immagine 2 di 2
    • If you don't have a liquid adhesive remover, you'll be using a hot iOpener to warm and soften a section of the adhesive securing the battery to the upper case, and then carefully prying at that point.
    • Use the hot iOpener to cover half of the two right-most battery cells.
    • After about a minute, reheat the iOpener and move it to cover the other half of the right-most battery cells.
  24. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 25, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 25, immagine 2 di 2
    • Push a plastic card between the right-most battery cell and the upper case, cutting the adhesive between the two.
    • Throughout this procedure, be careful not to damage any of the battery cells with your tools. A damaged lithium-ion battery may leak dangerous chemicals and/or catch fire. Use only plastic pry tools.
    • When using the hot iOpener method, if you encounter significant resistance to prying, stop and use the iOpener to reheat the section you're working on.
  25. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 26, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 26, immagine 2 di 2
    • Use the plastic card to pry the right-most battery cell up from the rear case.
  26. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 27, immagine 1 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 27, immagine 2 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 27, immagine 3 di 3
    • Repeat this procedure with the adjacent battery cell:
    • Apply a small amount of liquid adhesive remover under the battery cell, and wait 2-3 minutes for it to penetrate and soften the adhesive.
    • Alternatively, re-heat this section with your iOpener if needed.
    • Push a plastic card about an inch between the battery cell and the upper case, and slowly pry the cell up to separate all of the adhesive.
  27. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 28, immagine 1 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 28, immagine 2 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 28, immagine 3 di 3
    • Temporarily leave your plastic card underneath the two rightmost battery cells to prevent them from re-adhering to the upper case.
    • If using an iOpener, reheat it and reapply it, this time to the left-most battery cells.
    • Again, leave the iOpener in each position for about a minute, reheating in between, to heat each half of the left-most battery cells.
  28. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 29, immagine 1 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 29, immagine 2 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 29, immagine 3 di 3
    • Repeat the above procedure to separate the two leftmost battery cells from the upper case.
    • Remember to apply a small amount of adhesive remover to each battery cell, and wait 2-3 minutes for it to penetrate and soften the adhesive.
    • Use a second plastic card to separate the two leftmost battery cells from the upper case.
  29. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 30, immagine 1 di 1
    • Leave the second card in the corner between the two left cells.
    • In the following steps, you can either use a third card, or the card from the right corner. The right corner adhesive should be dry/cool enough that the cells can easily be pulled up again when needed.
  30. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 31, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 31, immagine 2 di 2
    • To separate the adhesive securing the final two, middle battery cells, apply a few more drops of liquid adhesive remover (or your iOpener) to each cell.
    • Apply the adhesive remover sparingly, since the trackpad lies beneath this area of the battery.
    • It may help to elevate one side of your MacBook Pro a few inches so that the adhesive remover flows in the correct direction, underneath the battery cells. You can use a sturdy book or foam block to prop up one side of your MacBook Pro while you work.
    • Insert the card about an inch between the left-center battery cell and the upper case, separating the adhesive between the cell and the case.
  31. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 32, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 32, immagine 2 di 2
    • Pull the card back out and insert it about an inch between the right-center battery cell and the upper case, separating the adhesive between the cell and case.
  32. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 33, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 33, immagine 2 di 2
    • By this point, the outer cells should be free, and you should only encounter resistance from the two center cells. If this is not the case, go back and completely loosen the four outer-most cells from the upper case.
    • Pry up on the two center cells to separate the last of the adhesive and lift the battery from the device.
  33. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 34, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 34, immagine 2 di 2
    • Remove the battery.
    • Before installing your new battery, remove all the old adhesive from the MacBook Pro's case.
    • With a little luck, you can slowly pull out each strip of adhesive with your fingers.
    • Otherwise, soak each section of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with an opening pick or one of the other tools in your kit. This can take quite a bit of work, so be patient.
    • Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
    • The replacement battery included in your iFixit kit comes with adhesive pre-installed. Test the battery's fit and alignment carefully before peeling off the film covering the adhesive, and then press each cell firmly into place. If any additional films/liners are present that weren't on your original battery, remove them now.
    • Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
  34. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement, Trackpad: passo 35, immagine 1 di 1
    • Place a reheated iOpener over the trackpad cover plate to soften the adhesive securing it to the upper case.
    • Be careful not to overheat the iOpener during the repair. Always wait at least two minutes before reheating the iOpener.
  35. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 36, immagine 1 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 36, immagine 2 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 36, immagine 3 di 3
    • Use a plastic opening tool to carefully pry the trackpad cover plate up from the upper case.
    • Go slowly and carefully to avoid putting any visible creases in the plate.
  36. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 37, immagine 1 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 37, immagine 2 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 37, immagine 3 di 3
    • Use a plastic opening tool to slowly and carefully peel the trackpad cover plate up off the upper case.
  37. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 38, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 38, immagine 2 di 2
    • Gently peel the plate up to remove it.
  38. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 39, immagine 1 di 1
    • If necessary, peel back any tape covering the trackpad cable connector.
  39. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 40, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 40, immagine 2 di 2
    • Use the tip of a spudger to flip the retaining tab on the ZIF connector.
  40. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 41, immagine 1 di 1
    • Pull the trackpad ribbon cable straight out of its socket on the logic board.
  41. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 42, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 42, immagine 2 di 2
    • Wedge the flat end of a spudger underneath the upper case opening where the trackpad ribbon cable passes is routed through.
    • Gently pry the trackpad ribbon cable from the adhesive securing it to the upper case.
  42. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 43, immagine 1 di 1
    • Remove the following screws securing the trackpad brackets to the trackpad and upper case.
    • Four 2.2 mm T5 Torx screws
    • Four 1.7 mm T5 Torx screws
  43. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 44, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 44, immagine 2 di 2
    • Use tweezers to remove the two trackpad mounting brackets from the upper case.
  44. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 45, immagine 1 di 2 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 45, immagine 2 di 2
    • To avoid scratching the display, open the computer about 90ยบ and set it on end.
    • Carefully guide the trackpad ribbon cable through the slot cut in the upper case.
    • This will push the trackpad up out of its recess in the top of the upper case.
    • Guide the trackpad out of the upper casewith your other hand, so it doesn't fall.
  45. MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 46, immagine 1 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 46, immagine 2 di 3 MacBook Pro 13" Retina Display Mid 2014 Trackpad Replacement: passo 46, immagine 3 di 3
    • Gently pull the trackpad away from the upper case, being careful not to snag the ribbon cable.
Conclusione
Altre 45 persone hanno completato questa guida.
Sam Goldheart
Membro da: 10/18/12
457.075 Reputazione
537 Guide realizzate
iFixit Membro di iFixit
Community
140 Membri
16.877 Guide realizzate
14 Commenti
I have a non clicking trackpad in a mid 2014 chassis, i brought it to the mac store and they say they found liquid damage throughout the computer. weather i believe them is besides the point it is a backup machine and I am not going to spend $700 to clean it out. There doesn't seam to be any trackpads for sale on here. Are they available?
peteuliana - Replica
Just replaced the trackpad on a Macbook Pro A1502. The customer had used the item very little and the trackpad had just failed completely. I found a seller on ebay with a brand new part and went about replacing it. The pentolope screws should have been no problem but one was cross threaded and would not come out. We had to drill it out. Big pain in the butt. Having swapped trackpads in Macbooks before this by comparison was much harder. The battery is glued in but upon further inspection it looks to have been designed to screw in and even has screw holes in the chassis and covered screw holes in the battery. This design seems to go along with the throw away mentality of apple. Apple store said water damage but there was none at all. They wanted 400$. The previous Macbook model they year before had recalled Trackpad issues but not this one???. Really crappy Apple dropped the ball on this one accusing customers of damage and doing nothing to replace a defective part. Thank You for the great fix it!!
Waynoenterprises - Replica
7/7/2016. I took my 15" retina to the Genius Bar at the Grove where I bought it 3 years ago, as the pointer was jumping around. It would settle down sometimes, then would act up again. A readout showed that the extreme rhs of the pad was not functioning. Had to leave it. Could not open and fix it at home. Was told this was a unibody, and the entire top of the case needs to be replaced. Will cost me $310 plus tax, and 4 days. They sure don't want us to fool with it!
john - Replica
I've a question. At first I want to say, my English is not the best but I hope you understand me and anyone can answer my question. I've also a problem with the trackpad and I studied this guide a lot. I will start in a few days to try to fix this by replacing the trackpad. The only question I have is, that when I have replaced the trackpad, does I have to use some new glue to stick the battery back in the macbook. Or will the glue which is already on the battery be enough ? I found some glue on amazon which u can use for iPhone displays or something like this and I'm probably going to use this one. Has anybody replaced his trackpad and could give me an answer ? Thanks in advance.. :)
markus ernst - Replica
Hello!! I have a Macbook Pro retina 13"(mid 2014) (model:A1502). Yesterday I took my mac to the technical service because the mouse is not working well, and I did'nt know if the problem was software or the trackpad.
They say it's the trackpad, but they should change the whole topcase, and it would cost me almost $ 700 to repair. They say that in this model can not be changed only the trackpad!!! From what I'm seeing here they did not tell me the truth.
How or where can I get a trackpad of this model to solve my problem? Amazon? How do I look for it and how much can it cost? Thanks a lot!!
Serena Zitarrosa - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 70
Ultimi 30 Giorni: 296
Tutti i Tempi: 68,689
