Salta al contenuto principale
MacBook Air 13" Early 2020 Lower Case Replacement
Cosa ti serve
  1. MacBook Air 13" Early 2020 Lower Case Replacement, Remove the screws securing the lower case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    Compra
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
  2. MacBook Air 13" Early 2020 Lower Case Replacement, Remove the lower case: passo 2, immagine 1 di 3 MacBook Air 13" Early 2020 Lower Case Replacement, Remove the lower case: passo 2, immagine 2 di 3 MacBook Air 13" Early 2020 Lower Case Replacement, Remove the lower case: passo 2, immagine 3 di 3
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
Conclusione
Carsten Frauenheim
Membro da: 03/10/20
113.712 Reputazione
338 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 59
Ultimi 30 Giorni: 216
Tutti i Tempi: 5,344
