Salta al contenuto principale
Mac mini Model A1283 Fan Replacement
Cosa ti serve
  1. Mac mini Model A1283 Fan Replacement, Top Housing: passo 1, immagine 1 di 2 Mac mini Model A1283 Fan Replacement, Top Housing: passo 1, immagine 2 di 2
    • Power down your Mac mini, disconnect all of the cables, and flip it over.
    • Insert the Jimmy into the crack between the aluminum top housing and the plastic lower housing.
    • The Jimmy should reach a stop about 3/8" down.
    Chiedi a FixBot
    Aggiungi Commento
  2. Mac mini Model A1283 Fan Replacement: passo 2, immagine 1 di 3 Mac mini Model A1283 Fan Replacement: passo 2, immagine 2 di 3 Mac mini Model A1283 Fan Replacement: passo 2, immagine 3 di 3
    • Gently bend the Jimmy outwards to pry the crack open a little larger and lift the lower housing up a small amount.
    • There are several plastic clips on the lower housing that fit into a channel in the aluminum top housing. Your goal is to use the Jimmy to push these clips inward enough to free them from the channel, while gently pulling up on the lower housing.
    Chiedi a FixBot
    Aggiungi Commento
  3. Mac mini Model A1283 Fan Replacement: passo 3, immagine 1 di 2 Mac mini Model A1283 Fan Replacement: passo 3, immagine 2 di 2
    • Once you have the first side free, rotate the Mac mini and start prying up on the front edge.
    • Use the same prying motion to both bend the clips inward and lift the lower housing up out of the top housing.
    Chiedi a FixBot
    Aggiungi Commento
  4. Mac mini Model A1283 Fan Replacement: passo 4, immagine 1 di 2 Mac mini Model A1283 Fan Replacement: passo 4, immagine 2 di 2
    • You may need to move the Jimmy along the edge to pry up all of the clips. Be patient and do a little bit at a time.
    Chiedi a FixBot
    Aggiungi Commento
  5. Mac mini Model A1283 Fan Replacement: passo 5, immagine 1 di 2 Mac mini Model A1283 Fan Replacement: passo 5, immagine 2 di 2
    • Keep working around the perimeter, freeing the clips along the final edge.
    Chiedi a FixBot
    Aggiungi Commento
  6. Mac mini Model A1283 Fan Replacement: passo 6, immagine 1 di 2 Mac mini Model A1283 Fan Replacement: passo 6, immagine 2 di 2
    • Flip the Mac mini back over and lift the top housing off of the lower housing.
    Chiedi a FixBot
    Aggiungi Commento
  7. Mac mini Model A1283 Fan Replacement, Internal Frame: passo 7, immagine 1 di 1
    • In the next few steps you will be removing the AirPort and Bluetooth antennas (shown in red) from the internal frame. Be very careful, as breaking the brackets will require replacing the internal frame.
    • We will first remove the AirPort antenna, located in the lower left corner of this picture.
    Chiedi a FixBot
    Aggiungi Commento
  8. Mac mini Model A1283 Fan Replacement: passo 8, immagine 1 di 2 Mac mini Model A1283 Fan Replacement: passo 8, immagine 2 di 2
    • Slightly squeeze the two retaining arms toward each other and lift the AirPort antenna off its post.
    • Squeezing the two posts excessively will surely break them off the internal frame. Work delicately.
    • During reinstallation, you will have to slightly squeeze the two posts together so they fit into the openings on the AirPort antenna board.
    Chiedi a FixBot
    Aggiungi Commento
  9. Mac mini Model A1283 Fan Replacement: passo 9, immagine 1 di 2 Mac mini Model A1283 Fan Replacement: passo 9, immagine 2 di 2
    • The two Bluetooth antenna boards simply lift off the internal frame.
    • Grab the Bluetooth antenna nearest the port side of the computer by the edges of the board and pull it straight up off the internal frame.
    • Pull carefully, as it may offer significant resistance and release suddenly.
    Chiedi a FixBot
    Aggiungi Commento
  10. Mac mini Model A1283 Fan Replacement: passo 10, immagine 1 di 1
    • Remove the antenna board near the front of the mini by pulling it straight up off the internal frame.
    • If necessary, remove the piece of tape securing the antenna leads to the internal frame.
    • Be sure to keep track of the springs under each of the three antenna boards.
    Chiedi a FixBot
    Aggiungi Commento
  11. Mac mini Model A1283 Fan Replacement: passo 11, immagine 1 di 1
    • Use the flat end of a spudger to pry the audio ribbon cable connector up off the audio board.
    Chiedi a FixBot
    Aggiungi Commento
  12. Mac mini Model A1283 Fan Replacement: passo 12, immagine 1 di 1
    • Remove the following four screws securing the internal frame to the bottom housing:
    • Three 6.7 mm Phillips #00 screws
    • One 9.5 mm Phillips #00 screw
    • The screw in the lower right corner of this image is recessed deep in the internal frame and longer than the other three screws. A flashlight and a thin screwdriver aid in removal.
    Chiedi a FixBot
    Aggiungi Commento
  13. Mac mini Model A1283 Fan Replacement: passo 13, immagine 1 di 1
    • Lift the internal frame off the bottom housing, starting at the rear edge, until you feel the concealed edge connector on the motherboard disconnect. Then lift straight off, minding the bluetooth and 802.11 antenna cables.
    • When reassembling, the wifi antenna wire routes to the inside of the vent and then over the top of the vent.
    Chiedi a FixBot
    Aggiungi Commento
  14. Mac mini Model A1283 Fan Replacement, Fan: passo 14, immagine 1 di 1
    • Remove the two Phillips screws securing the fan to the internal frame.
    Chiedi a FixBot
    Aggiungi Commento
  15. Mac mini Model A1283 Fan Replacement: passo 15, immagine 1 di 1
    • Use the flat end of a spudger to pry the fan connector up off the interconnect board.
    • The fan cable is the furthest left of the three connectors near the fan on the interconnect board.
    Chiedi a FixBot
    Aggiungi Commento
  16. Mac mini Model A1283 Fan Replacement: passo 16, immagine 1 di 1
    • De-route the fan cable from the channel in the internal frame.
    Chiedi a FixBot
    Aggiungi Commento
  17. Mac mini Model A1283 Fan Replacement: passo 17, immagine 1 di 1
    • Lift the fan out of the internal frame.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 27 persone hanno completato questa guida.
2Commenti sulla guida
Sure wish I hadn't seen the photo in step 14 of the appearance of prying off the fan connector as Ron states here in the *uckup section. I also appreciate ifixit for following Ron's suggestion......ha
Steven Fulton - Rispondi Condividi
I’ve just done the very same thing. But I’ve just ordered a new interconnect board and will follow this - Mac mini Model A1283 Interconnect Board Replacement very carefully. What I’ve just learned is to read the comments for each step individually before attempting it. And that my eyesight won’t let me do this kind of thing in a few years.
Dave Owen - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 15
Ultimi 30 giorni: 93
Tutti i Tempi: 36,014
