Salta al contenuto principale
Mac Pro First Generation RAM Replacement
    1. Mac Pro First Generation RAM Replacement, Case Panel: passo 1, immagine 1 di 1
      • Lift the lever to unlock the case.
      Chiedi a FixBot
      Aggiungi Commento
    2. Mac Pro First Generation RAM Replacement: passo 2, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      Anti-Static Wrist Strap
      $7.95
      • Remove the side panel of the Mac Pro.
      • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
      Chiedi a FixBot
      Aggiungi Commento
    1. Mac Pro First Generation RAM Replacement, RAM: passo 3, immagine 1 di 1
      • Locate the two RAM trays at the bottom of the Mac Pro.
      Chiedi a FixBot
      Aggiungi Commento
    2. Mac Pro First Generation RAM Replacement: passo 4, immagine 1 di 2 Mac Pro First Generation RAM Replacement: passo 4, immagine 2 di 2
      • Pull the RAM tray out of the case by using both hands holding the edge of the ram board as shown.
      • Make sure you give enough time for the computer to cool down before you remove any internal hardware parts.
      Chiedi a FixBot
      Aggiungi Commento
    3. Mac Pro First Generation RAM Replacement: passo 5, immagine 1 di 3 Mac Pro First Generation RAM Replacement: passo 5, immagine 2 di 3 Mac Pro First Generation RAM Replacement: passo 5, immagine 3 di 3
      • Push down on the ejectors on each side of a ram stick firmly and lift the RAM stick straight out carefully by holding each side.
      • To insert a new RAM stick, place the RAM into the slot with the correct orientation and push on the stick using both hands until the ejectors are clicked into place.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 22 persone hanno completato questa guida.
Andrew Kim
Membro da: 10/12/14
1.263 Reputazione
3 guide realizzate
Cal Poly, Team 6-24, Maness Fall 2014 Membro di Cal Poly, Team 6-24, Maness Fall 2014
CPSU-MANESS-F14S6G24
4 Membri
37 guide realizzate
2Commenti sulla guida
What is the name/or type of memory chip to use in the MacPro 2008.
Curtis - Rispondi Condividi
Hi Curtis, hope you found the RAM type ok.
Basically server RAM, ECC, 667Mhz, FB always in Pairs.
Retired Apple, PC etc engineer.
coopernewlyn - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 11
Ultimi 30 giorni: 68
Tutti i Tempi: 22,140
