Salta al contenuto principale
MSI GS70 Solid State Drive Replacement
Cosa ti serve
  1. MSI GS70 Solid State Drive Replacement, Solid State Drive: passo 1, immagine 1 di 2 MSI GS70 Solid State Drive Replacement, Solid State Drive: passo 1, immagine 2 di 2
    • Locate and remove all screws securing the back plate. Place the screws on the magnetic mat.
    • Locate one of the openings on the side and gently pull the back plate up to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  2. MSI GS70 Solid State Drive Replacement: passo 2, immagine 1 di 1
    • Locate the solid state drive. It is initially obscured by a connector, its okay to push away the connector to access the solid state drive.
    Chiedi a FixBot
    Aggiungi Commento
  3. MSI GS70 Solid State Drive Replacement: passo 3, immagine 1 di 1
    • Remove the screw holding the solid state drive. Place the screw on the magnetic mat
    Chiedi a FixBot
    Aggiungi Commento
  4. MSI GS70 Solid State Drive Replacement: passo 4, immagine 1 di 1
    • Gently remove the solid state drive.
    Chiedi a FixBot
    Aggiungi Commento
  5. MSI GS70 Solid State Drive Replacement: passo 5, immagine 1 di 1
    • There are different form factors for solid state drives and so you have to pick the appropriate one.
    • The MSI GS70 will only accept 50mm solid state drives so buy accordingly.
    Chiedi a FixBot
    Aggiungi Commento
  6. MSI GS70 Solid State Drive Replacement: passo 6, immagine 1 di 1
    • There is a second solid state drive right next to the first one if you want to add another solid state drive.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Once you have secured the solid state drive, push and screw in the back plate.
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 10
Ultimi 30 giorni: 30
Tutti i Tempi: 3,278
