Salta al contenuto principale
MSI Force GC30 V2 Battery Replacement
Cosa ti serve
  1. MSI Force GC30 V2 Battery Replacement, Back Cover: passo 1, immagine 1 di 1
    • Puncture the sticker where indicated using a screwdriver, then remove the 9.1 mm-long Phillips screw.
    • Remove the six 9.2 mm-long Phillips #0 screws.
  2. MSI Force GC30 V2 Battery Replacement: passo 2, immagine 1 di 3 MSI Force GC30 V2 Battery Replacement: passo 2, immagine 2 di 3 MSI Force GC30 V2 Battery Replacement: passo 2, immagine 3 di 3
    • Insert an opening pick in the gap between the front and rear case.
    • Slide the pick around the perimeter of the controller while prying until it fully releases.
  3. MSI Force GC30 V2 Battery Replacement, Battery: passo 3, immagine 1 di 1
    • Use tweezers to grip the white battery connector.
    • Pull the battery connector directly out of its port.
    • Do not pull on the wires.
  4. MSI Force GC30 V2 Battery Replacement: passo 4, immagine 1 di 1
    • The battery is secured to the motherboard with a mild adhesive. If necessary, apply a small amount of high-concentration isopropyl alcohol beneath the battery to loosen the adhesive.
    • Pry carefully around the battery until it fully releases.
    • Take care not to puncture or bend the battery.
    • Remove the battery.
Conclusione
For optimal performance, calibrate your newly installed battery after completing this guide.
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 79
Tutti i Tempi: 867
