Salta al contenuto principale
M3D Micro Data and Power Port Replacement
Cosa ti serve
    1. M3D Micro Data and Power Port Replacement, Data and Power Ports: passo 1, immagine 1 di 3 M3D Micro Data and Power Port Replacement, Data and Power Ports: passo 1, immagine 2 di 3 M3D Micro Data and Power Port Replacement, Data and Power Ports: passo 1, immagine 3 di 3
      • Place pressure on the central print bed and simultaneously pull up on the outer perimeter of the 3D printer. The cube shaped enclosure will lift up.
      Chiedi a FixBot
      Aggiungi Commento
    2. M3D Micro Data and Power Port Replacement: passo 2, immagine 1 di 3 M3D Micro Data and Power Port Replacement: passo 2, immagine 2 di 3 M3D Micro Data and Power Port Replacement: passo 2, immagine 3 di 3
      • Remove the print bed cover and locate the four screws holding the print bed to the base of the unit. Remove the four 9.5 mm screws using the 3.5 Hex head from the bit kit.
      Chiedi a FixBot
      Aggiungi Commento
    3. M3D Micro Data and Power Port Replacement: passo 3, immagine 1 di 2 M3D Micro Data and Power Port Replacement: passo 3, immagine 2 di 2
      • Lifting the print bed reveals the motherboard that controls the unit. This is the hardware that allows the printer to connect to the computer. The port on the left is the data and the port on the right is the power input.
      Chiedi a FixBot
      Aggiungi Commento
    4. M3D Micro Data and Power Port Replacement: passo 4, immagine 1 di 3 M3D Micro Data and Power Port Replacement: passo 4, immagine 2 di 3 M3D Micro Data and Power Port Replacement: passo 4, immagine 3 di 3
      • The ports are primarily soldered on to the board but are additionally secured using glue. Use the sharp metal spudger tool to gently pry apart the glue surrounding the ports.
      Chiedi a FixBot
      Aggiungi Commento
    5. M3D Micro Data and Power Port Replacement: passo 5, immagine 1 di 2 M3D Micro Data and Power Port Replacement: passo 5, immagine 2 di 2
      • To remove the charging port grasp the port with a pair of pliers and use a soldering iron to desolder the joints at the red marks while carefully pulling away with the pliers.
      Chiedi a FixBot
      Aggiungi Commento
    6. M3D Micro Data and Power Port Replacement: passo 6, immagine 1 di 2 M3D Micro Data and Power Port Replacement: passo 6, immagine 2 di 2
      • To replace the power port, match the four contact points on the board to the new port and carefully solder the components together.
      Chiedi a FixBot
      Aggiungi Commento
    7. M3D Micro Data and Power Port Replacement: passo 7, immagine 1 di 2 M3D Micro Data and Power Port Replacement: passo 7, immagine 2 di 2
      • To replace the USB data port, follow the same procedure as Step 5. The contact pins for the data port are on the back. The red marker indicates the four contact pins that must be matched up and carefully soldered on.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Ilian D
Membro da: 09/28/17
125 Reputazione
Una guida realizzata
USF Tampa, Team S3-G2, Nance Fall 2017 Membro di USF Tampa, Team S3-G2, Nance Fall 2017
USFT-NANCE-F17S3G2
4 Membri
10 guide realizzate
4Commenti sulla guida
Between the 2nd & 3rd images in step 1, the print head has vanished without explanation.
How do we remove the print head so we can remove the top half of the case to be able to proceed to step 2?
That’s the only piece if data missing.
Otherwise, it seems to be a great article.
Thank you.
Justin Hamilton - Rispondi Condividi
I found this document to replace the Z-Belt. It includes the steps to remove the print head.
https://micro.printm3d.com/technical-sup...
Can you advise what voltage this unit works on. I no longer have the cords.
P D - Rispondi Condividi
apparently 5V 4Amp and if 12V or more has ever even touched the power port... it is dead
Matthew Steuer - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 48
Tutti i Tempi: 2,441
