Salta al contenuto principale
Logitech UE Hyperboom DC Power Socket Replacement
Cosa ti serve
  1. Logitech UE Hyperboom DC Power Socket Replacement, Handle: passo 1, immagine 1 di 2 Logitech UE Hyperboom DC Power Socket Replacement, Handle: passo 1, immagine 2 di 2
    • Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
    • You may need pliers to grip the screws.
    Chiedi a FixBot
    Aggiungi Commento
  2. Logitech UE Hyperboom DC Power Socket Replacement, Bottom Panel: passo 2, immagine 1 di 2 Logitech UE Hyperboom DC Power Socket Replacement, Bottom Panel: passo 2, immagine 2 di 2
    • Use the Jimmy to pry off the four rubber feet on the bottom of the speaker.
    Chiedi a FixBot
    Aggiungi Commento
  3. Logitech UE Hyperboom DC Power Socket Replacement: passo 3, immagine 1 di 3 Logitech UE Hyperboom DC Power Socket Replacement: passo 3, immagine 2 di 3 Logitech UE Hyperboom DC Power Socket Replacement: passo 3, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove all twelve 11.7mm screws from the bottom panel of the speaker.
    • Pull the panel off to access the internal components.
    Chiedi a FixBot
    Aggiungi Commento
  4. Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: passo 4, immagine 1 di 3 Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: passo 4, immagine 2 di 3 Logitech UE Hyperboom DC Power Socket Replacement, DC Power Socket: passo 4, immagine 3 di 3
    • Unscrew the top 11.7m screw on the DC Power Socket panel using the Phillips #0 screwdriver.
    • Use the Jimmy to pry the panel away from the speaker, then disconnect the power cables from the daughterboard.
    Chiedi a FixBot
    Aggiungi Commento
  5. Logitech UE Hyperboom DC Power Socket Replacement: passo 5, immagine 1 di 2 Logitech UE Hyperboom DC Power Socket Replacement: passo 5, immagine 2 di 2
    • Remove the four 7.9mm screws from the daughterboard with the Phillips #0 screwdriver.
    • Pull the circuit board away from the panel.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
1Commento della guida
G'day I've got the 2024 version that has a broken charging port and can't find a PCB replacement anywhere I'm in New Zealand probably why but do you guys reckon I could just swap it out with the older version of the charging board since there available.
Ethan Donaldson - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 11
Ultimi 30 giorni: 41
Tutti i Tempi: 147
