Salta al contenuto principale
Logitech UE Boom USB Port Replacement
Cosa ti serve
  1. Logitech UE Boom USB Port Replacement, D-ring: passo 1, immagine 1 di 1
    • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
    Chiedi a FixBot
    Aggiungi Commento
  2. Logitech UE Boom USB Port Replacement: passo 2, immagine 1 di 2 Logitech UE Boom USB Port Replacement: passo 2, immagine 2 di 2
    • Lift the handle on the D-ring and unscrew it.
    • Remove the D-ring.
    Chiedi a FixBot
    Aggiungi Commento
  3. Logitech UE Boom USB Port Replacement, Bluetooth Adapter: passo 3, immagine 1 di 1
    • Any repairs made from this point forward will void your device's warranty.
    • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
    Chiedi a FixBot
    Aggiungi Commento
  4. Logitech UE Boom USB Port Replacement: passo 4, immagine 1 di 3 Logitech UE Boom USB Port Replacement: passo 4, immagine 2 di 3 Logitech UE Boom USB Port Replacement: passo 4, immagine 3 di 3
    • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
    • Repeat for the bottom of the speaker and pry the casing open with your fingers.
    Chiedi a FixBot
    Aggiungi Commento
  5. Logitech UE Boom USB Port Replacement: passo 5, immagine 1 di 2 Logitech UE Boom USB Port Replacement: passo 5, immagine 2 di 2
    • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
    • Do the same for the two black 7 mm screws.
    Chiedi a FixBot
    Aggiungi Commento
  6. Logitech UE Boom USB Port Replacement: passo 6, immagine 1 di 3 Logitech UE Boom USB Port Replacement: passo 6, immagine 2 di 3 Logitech UE Boom USB Port Replacement: passo 6, immagine 3 di 3
    • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
    • Using a soldering iron, de-solder the two ends of the switch plate. Desolder the two terminals on headphone jack side first, as the middle connection is notched and should be slid out when molten.
    Chiedi a FixBot
    Aggiungi Commento
  7. Logitech UE Boom USB Port Replacement: passo 7, immagine 1 di 1
    • With the switch plate disconnected, remove it and your device should now look like this.
    Chiedi a FixBot
    Aggiungi Commento
  8. Logitech UE Boom USB Port Replacement, Lithium Battery: passo 8, immagine 1 di 1
    • With a metal spudger, pry open the tabs on the speaker sleeve along the length of the speaker.
    Chiedi a FixBot
    Aggiungi Commento
  9. Logitech UE Boom USB Port Replacement: passo 9, immagine 1 di 1
    • Use a plastic opening tool to pry the sleeve off from the bottom of the speaker.
    Chiedi a FixBot
    Aggiungi Commento
  10. Logitech UE Boom USB Port Replacement: passo 10, immagine 1 di 3 Logitech UE Boom USB Port Replacement: passo 10, immagine 2 di 3 Logitech UE Boom USB Port Replacement: passo 10, immagine 3 di 3
    • Peel off the sleeve.
    Chiedi a FixBot
    Aggiungi Commento
  11. Logitech UE Boom USB Port Replacement: passo 11, immagine 1 di 2 Logitech UE Boom USB Port Replacement: passo 11, immagine 2 di 2
    • Use a Phillips 1 screwdriver to unscrew the eight black 14 mm screws along the length of the casing.
    Chiedi a FixBot
    Aggiungi Commento
  12. Logitech UE Boom USB Port Replacement: passo 12, immagine 1 di 2 Logitech UE Boom USB Port Replacement: passo 12, immagine 2 di 2
    • With the screws removed, pry open the casing to be able to get to the components inside.
    • Try prying the case open from one of the ends if that is easier.
    Chiedi a FixBot
    Aggiungi Commento
  13. Logitech UE Boom USB Port Replacement: passo 13, immagine 1 di 2 Logitech UE Boom USB Port Replacement: passo 13, immagine 2 di 2
    • With a Phillips #00 screwdriver, unscrew two 5.6 mm screws from the rectangular shaped circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  14. Logitech UE Boom USB Port Replacement: passo 14, immagine 1 di 1
    • With the Phillips #2 screwdriver, unscrew the 9.9 mm screw from the larger circuit board surrounding the speaker.
    Chiedi a FixBot
    Aggiungi Commento
  15. Logitech UE Boom USB Port Replacement: passo 15, immagine 1 di 1
    • Once all of the screws are gone, you should be able to remove the circuit boards and find the battery.
    Chiedi a FixBot
    Aggiungi Commento
  16. Logitech UE Boom USB Port Replacement: passo 16, immagine 1 di 2 Logitech UE Boom USB Port Replacement: passo 16, immagine 2 di 2
    • Remove the battery by pulling it from the terminal as marked in the picture.
    Chiedi a FixBot
    Aggiungi Commento
  17. Logitech UE Boom USB Port Replacement, USB Port: passo 17, immagine 1 di 2 Logitech UE Boom USB Port Replacement, USB Port: passo 17, immagine 2 di 2
    • Finally, after opening the speaker, locate the USB plate on the left face of the speaker and remove it from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 9 persone hanno completato questa guida.
Sean Reilly
Membro da: 10/01/15
1.784 Reputazione
2 guide realizzate
Cal Poly, Team 4-1, Maness Fall 2015 Membro di Cal Poly, Team 4-1, Maness Fall 2015
CPSU-MANESS-F15S4G1
4 Membri
28 guide realizzate
13Commenti sulla guida
Hello,
does anyone know where to get new usb port, the logitech support didn´t really help.
cheers marius
kok0dora94 - Rispondi Condividi
Same question as above, where can i buy a replacement USB port?
Corbett Hix - Rispondi Condividi
i found 10 of them on ebay for 3-4 dollars
johnsonjohnsonalexalex - Rispondi Condividi
Hi there , can you give me a link to Ebay where to find this port, thanks
katiecrow - Rispondi Condividi
can you send me a link on ebay where to find this replacement port , thanks
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 34
Ultimi 30 giorni: 187
Tutti i Tempi: 38,729
