Salta al contenuto principale
Logitech UE Boom 3 Battery Replacement
Cosa ti serve
  1. Logitech UE Boom 3 Battery Replacement, Base: passo 1, immagine 1 di 2 Logitech UE Boom 3 Battery Replacement, Base: passo 1, immagine 2 di 2
    • Flip the speaker so the base is facing upwards.
    • Place the iFixit opening picks in the gaps of the speaker.
    • Use the picks to pry open the speaker.
    Chiedi a FixBot
    Aggiungi Commento
  2. Logitech UE Boom 3 Battery Replacement: passo 2, immagine 1 di 2 Logitech UE Boom 3 Battery Replacement: passo 2, immagine 2 di 2
    • Use a Jimmy to completely pry the base away from the rest of the speaker.
    Chiedi a FixBot
    Aggiungi Commento
  3. Logitech UE Boom 3 Battery Replacement, Battery: passo 3, immagine 1 di 3 Logitech UE Boom 3 Battery Replacement, Battery: passo 3, immagine 2 di 3 Logitech UE Boom 3 Battery Replacement, Battery: passo 3, immagine 3 di 3
    • Remove the adhesive strap holding the battery in place.
    • It is sticky and tightly bounded, but removal is necessary.
    • Pull out the battery by hand until it is out of the casing and being held by the cable only.
    Chiedi a FixBot
    Aggiungi Commento
  4. Logitech UE Boom 3 Battery Replacement: passo 4, immagine 1 di 2 Logitech UE Boom 3 Battery Replacement: passo 4, immagine 2 di 2
    • The battery will still be attached to motherboard via cable.
    • Carefully press down on the lever on the end of the cable and disconnect it from the motherboard.
    • This cable is intricate and is susceptible to damage beyond repair. Be extra careful to precisely insert and remove the cable as bending the pins can result in damage.
    • Remove the battery from the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 40
Ultimi 30 giorni: 263
Tutti i Tempi: 5,363
