Salta al contenuto principale
Logitech Performance MX Disassembly
    1. Logitech Performance MX Disassembly, Remove the Mouse Feet: passo 1, immagine 1 di 2 Logitech Performance MX Disassembly, Remove the Mouse Feet: passo 1, immagine 2 di 2
      • Peel off the three thin, plastic mouse feet on the bottom of the mouse. Make sure to carefully remove the adhesive along with the pad.
      • Use a thin flat object such as a flathead screwdriver to help remove if necessary.
      Chiedi a FixBot
      Aggiungi Commento
    2. Logitech Performance MX Disassembly, Remove the First Four Screws: passo 2, immagine 1 di 2 Logitech Performance MX Disassembly, Remove the First Four Screws: passo 2, immagine 2 di 2
      • Using a screwdriver, unscrew the four screws that were under the mouse feet.
      • Remove the battery from the mouse if not done already.
      Chiedi a FixBot
      Aggiungi Commento
    3. Logitech Performance MX Disassembly, Separate the Top and Bottom: passo 3, immagine 1 di 3 Logitech Performance MX Disassembly, Separate the Top and Bottom: passo 3, immagine 2 di 3 Logitech Performance MX Disassembly, Separate the Top and Bottom: passo 3, immagine 3 di 3
      • Gently pull the top of the mouse off from the base, making sure the wires and components are in place.
      • Carefully pull out the white enclosure from its port to safely take the top apart from the bottom.
      Chiedi a FixBot
      Aggiungi Commento
    4. Logitech Performance MX Disassembly, Remove the Scroll Wheel Base: passo 4, immagine 1 di 2 Logitech Performance MX Disassembly, Remove the Scroll Wheel Base: passo 4, immagine 2 di 2
      • Pull out the plastic pin in-between the scroll wheel and the battery enclosure and pull up on the scroll wheel base to remove.
      Chiedi a FixBot
      Aggiungi Commento
    5. Logitech Performance MX Disassembly, Unscrew for the Battery Capsule: passo 5, immagine 1 di 2 Logitech Performance MX Disassembly, Unscrew for the Battery Capsule: passo 5, immagine 2 di 2
      • Remove the 2 small springs underneath the scroll wheel base.
      • Unscrew the four screws holding the battery capsule onto the PCB.
      Chiedi a FixBot
      Aggiungi Commento
    6. Logitech Performance MX Disassembly, Unplug the Ribbon Cable: passo 6, immagine 1 di 2 Logitech Performance MX Disassembly, Unplug the Ribbon Cable: passo 6, immagine 2 di 2
      • Unplug the ribbon cable from the circuit board. Be careful to not remove the cable’s locking mechanism.
      Chiedi a FixBot
      Aggiungi Commento
    7. Logitech Performance MX Disassembly, Remove Scroll Wheel Support: passo 7, immagine 1 di 2 Logitech Performance MX Disassembly, Remove Scroll Wheel Support: passo 7, immagine 2 di 2
      • Unscrew the four screws to take out the black scroll wheel support in the center and the two black pads that lie on both sides of the support.
      Chiedi a FixBot
      Aggiungi Commento
    8. Logitech Performance MX Disassembly, Pull Up Circuit Board: passo 8, immagine 1 di 2 Logitech Performance MX Disassembly, Pull Up Circuit Board: passo 8, immagine 2 di 2
      • Pull the circuit board up to find the on and off switch. Take out the clear plastic bit that held the springs.
      Chiedi a FixBot
      Aggiungi Commento
    9. Logitech Performance MX Disassembly, Disassembly Finished!: passo 9, immagine 1 di 1
      • All parts should be visible to repair or for replacement.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
1Commento della guida
Although useful, sadly this guide does not show how to disassemble the upper parts where the 3 switches for zoom, back and forward are located. Step 3 is the only place that shows this area, but only focuses on the disconnection of it.
Phil Millard - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 26
Ultimi 30 giorni: 122
Tutti i Tempi: 5,578
