Salta al contenuto principale
Logitech MBJ58 Mouse Resistance Spring Replacement
Cosa ti serve
  1. Logitech MBJ58 Mouse Resistance Spring Replacement, Top cover: passo 1, immagine 1 di 1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
    Chiedi a FixBot
    Aggiungi Commento
  2. Logitech MBJ58 Mouse Resistance Spring Replacement: passo 2, immagine 1 di 2 Logitech MBJ58 Mouse Resistance Spring Replacement: passo 2, immagine 2 di 2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
    Chiedi a FixBot
    Aggiungi Commento
  3. Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, immagine 1 di 3 Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, immagine 2 di 3 Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, immagine 3 di 3
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
    Chiedi a FixBot
    Aggiungi Commento
  4. Logitech MBJ58 Mouse Resistance Spring Replacement, Support Spring: passo 4, immagine 1 di 2 Logitech MBJ58 Mouse Resistance Spring Replacement, Support Spring: passo 4, immagine 2 di 2
    • Locate the spring on the scroll wheel, and carefully remove the spring.
    Chiedi a FixBot
    Aggiungi Commento
  5. Logitech MBJ58 Mouse Resistance Spring Replacement, Attaching the New Spring: passo 5, immagine 1 di 2 Logitech MBJ58 Mouse Resistance Spring Replacement, Attaching the New Spring: passo 5, immagine 2 di 2
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
    Chiedi a FixBot
    Aggiungi Commento
  6. Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: passo 6, immagine 1 di 3 Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: passo 6, immagine 2 di 3 Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: passo 6, immagine 3 di 3
    • Use the images to locate where the resistance spring is.
    • This spring will easily fall off.
    • Grab the scroll wheel and its mount and gently pull them apart.
    Chiedi a FixBot
    Aggiungi Commento
  7. Logitech MBJ58 Mouse Resistance Spring Replacement, Resistance Spring: passo 7, immagine 1 di 2 Logitech MBJ58 Mouse Resistance Spring Replacement, Resistance Spring: passo 7, immagine 2 di 2
    • Grasp the top of the resistance spring and pull it towards yourself, letting the hook slide out of its hole.
    Chiedi a FixBot
    Aggiungi Commento
  8. Logitech MBJ58 Mouse Resistance Spring Replacement: passo 8, immagine 1 di 1
    • Insert the hooked section of the replacement spring into the corresponding hole on the mount.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 15 persone hanno completato questa guida.
Cal Poly, Team 5-14, Forte Winter 2013 Membro di Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Membri
23 guide realizzate
10Commenti sulla guida
This mouse was also available from Dell as an OEM device under the model name "M-UVDEL1". Hopefully the Google juice will help folks repair their devices. I know I would have spent far more time than I did if it weren't for the photos on how to put the spring back. Thanks Maximilian!
Bastien Nocera - Rispondi Condividi
The spring installation details were lifesavers. Thank you!
LB
byard - Rispondi Condividi
thank you! could not have done it without your help.
taiyo_yuden_dvd - Rispondi Condividi
Brilliant. Thanks. Easy once you know how. The springs were the hard part.
Charles Thomson - Rispondi Condividi
Thank you so much!! You made it very easy and quick!
vulcanmeister - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 15
Ultimi 30 giorni: 81
Tutti i Tempi: 13,537
