Salta al contenuto principale
Logitech M705 Button Failure Fix
Cosa ti serve
    1. Logitech M705 Button Failure Fix, Dissassembly and problem identification: passo 1, immagine 1 di 2 Logitech M705 Button Failure Fix, Dissassembly and problem identification: passo 1, immagine 2 di 2
      • Follow the teardown guide to disassemble the mouse
      • The pad in the upper shell of the mouse that presses on the microswitch has worn , circled red in the photograph. Comapre the wear on this side with the lower level of wear in the equivalent part for the right hand mouse on the left side of the photograph. A close up of the worn part is shown in thhe second photogrpah
      Chiedi a FixBot
      Aggiungi Commento
    2. Logitech M705 Button Failure Fix, Use of insulation tape to resolve problem: passo 2, immagine 1 di 1
      • Use electrical insulation tape (blue in the photographs) to build up the level of the worn pad. Here I've used four layers
      • Then reassemble the mouse
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
To reassemble your device, reverse the dissasembly process as per the Teardown Guide.
Nick Knows
Membro da: 08/08/25
115 Reputazione
Una guida realizzata
1Commento della guida
This fixed an issue for me where the mouse buttons were bouncing (double clicking when trying to hold the button down).
user5219 - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 14
Ultimi 30 giorni: 56
Tutti i Tempi: 658
