Salta al contenuto principale
Logitech M570 Wireless Trackball Switches Replacement
Cosa ti serve
    1. Logitech M570 Wireless Trackball Switches Replacement, Preparation: passo 1, immagine 1 di 3 Logitech M570 Wireless Trackball Switches Replacement, Preparation: passo 1, immagine 2 di 3 Logitech M570 Wireless Trackball Switches Replacement, Preparation: passo 1, immagine 3 di 3
      • Remove tracking ball
      • Turn power switch to the off position
      • Open battery door
      • Remove AA battery
      Chiedi a FixBot
      Aggiungi Commento
    2. Logitech M570 Wireless Trackball Switches Replacement, Taking mouse body apart: passo 2, immagine 1 di 1
      • Remove 3 pads as shown in the picture
      • Unscrew the 5 bolts using Phillips #1 screwdriver
      • The last screw is hidden under the battery label. You will have to poke a hole to get to it.
      Chiedi a FixBot
      Aggiungi Commento
    3. Logitech M570 Wireless Trackball Switches Replacement, Detaching PCB: passo 3, immagine 1 di 3 Logitech M570 Wireless Trackball Switches Replacement, Detaching PCB: passo 3, immagine 2 di 3 Logitech M570 Wireless Trackball Switches Replacement, Detaching PCB: passo 3, immagine 3 di 3
      • Lift the latch up and pull flex circuit out of connector. Detach tracking ball sensor.
      • Unscrew first screw and detach little PCB
      • Take the other 3 screws out. The last screw is hidden behind a capacitor in the picture
      Chiedi a FixBot
      Aggiungi Commento
    4. Logitech M570 Wireless Trackball Switches Replacement, Removing PCB: passo 4, immagine 1 di 2 Logitech M570 Wireless Trackball Switches Replacement, Removing PCB: passo 4, immagine 2 di 2
      • Carefully remove PCB. Take care not to bend battery connector
      • Remove power switch. Otherwise it might fall out and you will never see it again...
      Chiedi a FixBot
      Aggiungi Commento
    5. Logitech M570 Wireless Trackball Switches Replacement, Replacing switches: passo 5, immagine 1 di 3 Logitech M570 Wireless Trackball Switches Replacement, Replacing switches: passo 5, immagine 2 di 3 Logitech M570 Wireless Trackball Switches Replacement, Replacing switches: passo 5, immagine 3 di 3
      • As you may see one of the switches is completely busted. It has to be replaced!
      • There are few replacements out there. I've used this one. But you might want to use original one. Or the rival one.
      • It really does not matter much. The difference is operating force. The original one comes with 75 gf which gives lighter clicking action. But I went with 150 gf for the replacement since those should last longer...
      • Take old switches out. Might be a little tricky! You might want to use multiple soldering irons to heat all 3 pins at once. Or heat gun. The choice is yours. Just be careful not to burn yourself! FYI, this is probably not the best project for the first soldering experience!
      • Solder new switches on.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
To reassemble your device, follow these instructions in the reverse order.
Altre 40 persone hanno completato questa guida.
Kirill
Membro da: 04/11/17
1.640 Reputazione
2 guide realizzate
24Commenti sulla guida
Instructions are very clear and accurate. The most difficult part of this repair is de-soldering the switch, additional information is needed for this step.
Hugo Castro - Rispondi Condividi
Yeah, you either have to use 2 irons to apply heat to 3 pins at the same time. Or take apart body of the switch and cut one of the pins from the body. That way you can use one iron to apply heat to 2 pins at the same time to get it detached from PCB
Kirill - Rispondi Condividi
Folks, use a solder sucker and a solder wick. There should be many articles out there on using solder (extractor) sucker and wick. But basically you melt solder , solder sucker sucks up the most of it (Put the tip right over the end of the metal leg RIGHT after melting) All has to happenen very quickly.
Then the solder wick, you rub over the metal pins using the solder iron to push it along the PCB around the pins and the switch will just drop out.
No offence to any one but the article author did say not advised for your first solder experience, and using solder wick etc would be a veteran solder master trick.
https://www.google.com/url?sa=t&rct=j&q=...
john sloan - Rispondi Condividi
Fine multi-strand wire from an old phone extension cable is good as a wick to remove solder - use a tiny amount of flux to help.
Christopher - Rispondi Condividi
An aside to replacing the switches: if you’re having problems with click bounce and a regular contact cleaner isn’t working you could try an oil for electric model train motor commutators: Peco Electrics Power-Lube PL-64 - I picked up a little in a model shop but you can buy it online in the UK for around £6 to £7 for a couple of mL - the key bounce problems have largely disappeared after one or two applications both for my M570s and for an older cordless trackman wheel that I had given up on. If you have one of these it is worth noting that they will run perfectly well on NiMH rechargeable cells whereas the M570 will not. The latter may win out on simple battery life but on the environmental side: using a rechargeable cell should be better in the longer term especially as the grid gets a higher proportion of renewables.
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 27
Ultimi 30 giorni: 133
Tutti i Tempi: 25,669
